If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Follow us on Facebook Follow us on Twitter
Page 2 of 5 FirstFirst 1234 ... LastLast
Results 11 to 20 of 41
  1. #11
    VIP Member VIP Member Back4More's Avatar
    My Boats:
    353 Fastech
    Join Date
    Feb 2002
    Lake Michigan
    Re: What was the first stepped V-Bottom??
    Quote Originally Posted by Semper Fi
    Like you knew this also just got schooled when you found this info on the net
    You got it!
  2. #12
    Registered Semper Fi's Avatar
    Join Date
    Oct 2000
    Quote Originally Posted by Back4More
    You got it!
    I was just messing with you....thanks for the info
  3. #13
    Registered formula31's Avatar
    My Boats:
    1988 Cruisers 2800 Rogue
    Join Date
    Mar 2001
    Quote Originally Posted by gotime34
    Interesting stuff there guys...that was a hell of a history lesson, thanks for the info.
    I was looking more for the progression of stepped hulls through the last decade. How come most manufacturers are making stepped hulls now, but some aren't, such as Sonic?
    Those who are, wanna go fast in flat water, those who arent, want to go fast and turn without changing ends.
  4. #14
    GLH is offline
    Platinum Member Platinum Member GLH's Avatar
    My Boats:
    Join Date
    Dec 2002
    Burlington, VT
    You guys know nothing.... Stepped Hulls
    The concept was originally proposed by Rev. Ramus of Sussex England in 1872. He proposed both a single step with tandem planing surfaces, and a combination of three pontoons with one forward and two aft. Indications are that these shapes were derived from model tests. Unfortunately, the heavy steam power plants of that day could not push a hull fast enough to plane, and take advantage of the new concept.
    As early as 1906 there were published drawings for small stepped hulls with hard chines. William Henry Fauber [8] obtained a U.S. patent for hulls with multiple steps in 1908, but could find few people in the U.S.A. interested, so he moved to Europe.
    Two small boats Solair (12') and Flapper (15') demonstrated the potential of stepped hulls as did the Harmsworth challenger Pioneer (5 steps) in 1910. (See Data Chart, Figure 12.)
    The stepped hull began practical development about at the same time as the hard chined planing hull. A step in the bottom of a hull, raises part of the bottom surface so that it is no longer touching the water. Less wetted area. At the same time, the planing surfaces meet the water at a near optimum angle of attack over a wide range of speeds. The stepped hull is very efficient hydrodynamicly.
    In the early days of stepped hulls, it was not certain just how many steps should be incorporated. Pioneer had 5 steps in 1910. Maple Leaf IV had 5 steps.
    Maple Leaf IV: Length 39'-11" x Beam 8' . Two V-8 engines 350 Hp. each.
    In 1912, Maple Leaf IV came over, from England, won the Harmsworth Trophy, and took it home. She had no less than five steps, and the driver sat on a pedestal high above the transom in order to see over the bow.
    Some hulls had so many steps that they were called "shingled'. Rainbow IV (12 steps);
    Eventually, model tests showed that a single step would be most efficient if you could locate it in the right position and the proper depth.
    The lines shown in Figure 10 are typical of stepped hulls in the 1920's. Note the very flat bottom. This boat raced in a class limited to engines with 1.5 litre displacements.
    Gar wood brought the Harmsworth Trophy back to United States in 1920 with the first of his Miss America's. These single stepped craft so dominated the Gold Cup and Harmsworth racing that few other boats attempted to compete. The Miss America series were not really efficient boats, just big boats with huge amounts of power from multiple V-12 Packard engines.
    Between about 1915 and 1940, a great many motor torpedo boats and fast patrol boats were built world wide, with stepped hulls. [10] The performance of these craft varied considerably, with some being very inefficient.
    Stepped Hull Limitations
    The stepped hull maintains a nearly optimum angle of attack over most of the speed range. The hydrodynamic hull drag is almost constant. The drag of the propeller shaft, shaft strut and rudder, (appendage drag) increase as the square of the speed.
    The graph of Performance Factors shows actual speed data of different prominent racing stepped hulls. The data points are numbered and refer to numbers on the data chart Figure 12. The boats are numbered in sequence according to the year when the speeds were established. The sequential increases in power factor reflect engine development and not hull development. Notice that most of these boats perform almost on the limit line. Gar Wood's Miss Americas were really quite inefficient. Many stepped hulls from England were significantly more efficient and often faster. They failed to win races because of a lack of strength and mechanical reliability. The very streamlined Alagi was slightly more efficient than the others.
    Stepped hulls are difficult to design. There are many design variables compared to the design of a Vee bottomed monohull. I do not know of any accurate method available to optimize stepped hull design other than by model testing.
    Stepped hulls dominated race boat design until about 1938 when Adolph Apel patented the three point hydroplane configuration. Ventnor three point hydroplanes dominated small limited class racing, yet stepped hulls were running competitively in Unlimited class racing up until 1949. In 1950, Slo-Mo-Shun demonstrated 'prop riding' and boosted the world speed record significantly. (More on 'prop riding" later.)
    Stepped hulls definitely have the potential of being significantly more efficient than rnonohulls.
    Compare the Limit Lines on the Performance Factor graphs. There are a number of reasons why stepped hulls did not become popular for pleasure boats.
    (a) Complexity of design, and the costs of development.
    (b) Stepped hulls were banned from gold cup racing from 1920 to 1931. Wealthy race boat owners were not investing in stepped hull development.
    (c) There were quite a few relatively small stepped 'gentleman's racers' built, but few of these were really efficient.
    (d) There were many huge war-surplus aircraft engines available after the first world war, at reasonable prices, and few light weight marine engines available. It was easier, (and possibly cheaper) to buy a big engine for a monohull, than to develop an efficient stepped hull.
    OSO....You have been schooled
    So if I get this right it was Professor Plum with the Cattle-prod in the Library?
  5. #15
    Registered masher44's Avatar
    Join Date
    Sep 2004
    Quote Originally Posted by skopi55
    Fountain went to the stepped hull in 1995. 1994 was still a flat bottom boat.
    My 1994 CS 24 beak was a stepped hull
  6. #16
    Registered Pure Energy's Avatar
    My Boats:
    2001 Superboat Y2K
    Join Date
    Oct 2000
    N. NJ, Eastern LI
    I remember seeing a late 80's 32 Hustler for sale with steps.
  7. #17
    VIP Member VIP Member JaayTeee's Avatar
    My Boats:
    2002 baja 33 o/l 575sci's
    Join Date
    Nov 2002
    Quote Originally Posted by PatriYacht
    Hustler had a stepped 40 in 1989. You could get it with big power and Arnesons too.
    The 40 Hustler is the first one I remember.
  8. #18
    Registered VIP Member
    My Boats:
    Join Date
    Jan 2004
    Boca Raton, FL
    Paul Fiore, father of Mike of Outer Limits, experimented many years ago with the Hustler bottom. Europeans had steps in cat hulls long before that.
    At the 1995 boat show when Reggie first displayed his stepped bottom, Paul told me Reggie was five years behind. Reggie has tweaked his steps many times since then.
  9. #19
    A to Z Platinum Member Sean H's Avatar
    Join Date
    Apr 2004
    the vikings would stagger the planks on their longships to gain more speed.. anybody got something farther back than that? maybe noah?
  10. #20
    Join Date
    Jun 2005
    Quote Originally Posted by jb
    Obsession has one in the early 90's, I doubt that was first....S. Stepp had to have his hand in there somewhere...
    According to Velocity's website Steve Stepp doesn't believe in the stepped hull and had nothing to do with it. He is known for the padded bottom as a solution for going fast on flat water. Works good too I have seen several 28's +/- that run 70+ with a single 496 HO.
Similar Threads
  1. Dry Storing a Stepped Hull: Is a stepped bunk required?
    By PhantomChaos in forum General Boating Discussion
    Last Post: 06-01-2011, 08:09 PM
  2. Apache's available with stepped bottom?
    By kgshooty in forum General Boating Discussion
    Last Post: 05-27-2008, 01:08 PM
  3. Stepped bottom 36 with a staggered 525 set-up.
    By onesickpantera in forum Pantera
    Last Post: 11-27-2006, 03:50 PM
  4. Tips for driving stepped bottom boats
    By thunderdan in forum General Boating Discussion
    Last Post: 01-11-2005, 01:34 PM
  5. I spun out this weekend, non stepped bottom
    By BajaRunner in forum General Boating Discussion
    Last Post: 06-07-2004, 12:16 PM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Powered by vBulletin® Version 4.2.0
Copyright © 2016 vBulletin Solutions, Inc. All rights reserved.
Search Engine Optimization by vBSEO 3.6.1
Original Poster In Postbit provided by Original Poster In Postbit v1.0.0 (Free) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd. Runs best on HiVelocity Hosting.
