Winterizing 496 or 496HO or 496Mag
#72
I have 2006 model year 496 ho. This set up does not have a standard fuel filter/water seperator. There is an inline fuel filter as well as a small elemental type filter that is located in the fuel body. I have done the fuel seperator/oil method on my older 502's, but since these engines do not have the seperator, where would the oil go? The capacity of this area is no more than 3 ounces also.
#74
I have a question. I winterized my 496`s and couldnt get the motors to prime with the air pressure menthod on it own. I wound up having to run water to the drives and finally getting it to go thru the exhaust. Then I hooked up the antifreeze with the air pressure method. I then had pink coming out the exhaust. But I didnt drain the water before I ran the antifreeze to it. Thinking that it wouldnt prime up the pump. Do you think that is OK? Or do I need to start over? This is the first year of winterizing this boat
#75
Which AF did you use? -50 or -100?
#76
It seemed alot of the antifreeze just ran out the front of the drives (bravo1). But like I said earlier. There was antifreeze coming out if the exhaust. The boat is store in my shop in a truck bay. So I wouldn't think it would get to cold. Maybe upper 20's at the most.
#78
