brovo cable adjustment tool
Does any one have a diagram of how to use tool 91-17262, if so please send to__ [email protected] Thanks Ken
Re: brovo cable adjustment tool
Let me scan the pages, Ill email then
sent
Thanks, haven't got them yet........Ken in elyria
Sent them again now, let me know.
nothing yet...............ken
Sent you an email without the pic to see if thats the problem and if the email is correct
3 Attachment(s)
HERE YOU GO HOPE IT HELPS,If you need more info call me or let me know!!!
Aw heck, just slowly move the adjustment cable in the slot in short increments until it works equaly in both gears. :D
When I reversed my props from in to out and swapped the shifter throws around, I still had to fiddle with the adjustment as the one drive would not fully engage in 1 direction after the swap. The adjustment was not changed prior either and is independent of the shifter to shifter bracket thinga magig. The adj. tool did not work in my case. I moved the adjustment from 1 extreme to the other in both gears, then tightened at the mid point. |
Originally Posted by GOODT
(Post 1553061)
My apologise for my poor english :rolleyes: |
