If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Follow us on Facebook Follow us on Twitter
Page 3 of 3 FirstFirst 123
Results 21 to 25 of 25
  1. #21
    Platinum Member Platinum Member Quiet Storm's Avatar
    Join Date
    Apr 2002
    Lake Michigan
    Re: 575's bad rap ??
    Quote Originally Posted by 10x
    Like Biggus said earlier, a mild hyd roller cam, a touch more static compression, and the 700 hp mark is not out of line. These 575's had just a light clean up on the heads in the bowl area, and a port match. A smaller top pulley that gave 1 more lb of boost, and 709 hp @ 5500, and I believe around 5.3 lbs boost.
    Roger, correct me if I'm wrong, I think you've got the dyno sheets.
    I've been holding out on this information. Keeps people thinking how can he get that barge going so fast with mild power. One nice thing is Jeff was able to get that much power out of them without intercoolers. I guess we are lucky that Lake Michigan doesn't get too hot.
    The drives are the weak link now but there are options.
  2. #22
    My Boats:
    382 formula
    Join Date
    Sep 2005
    Solana Beach,CA
    Quote Originally Posted by Shah Mat
    I have a buddy with the EXACT same issues. Under 200hrs and had rear bearing problems with one of the blowers. I've seen his gas bill, yes those motors like fuel, not to mention going the extra distance to get to a marina that sells 92. And.... he's had XR problems, both sides.
    Other than that, it's an awesome boat and the 575's make it "that much nicer".
    So whats the issue with XR drives & 575's? and the fix...keep the ass end in the water??
  3. #23
    VIP Member VIP Member JaayTeee's Avatar
    My Boats:
    2002 baja 33 o/l 575sci's
    Join Date
    Nov 2002
    Quote Originally Posted by 382 newbie
    Here's what happened to mine:
    Starboard drive: pinion gear started to chunk out,
    vertical drive shaft bearing failed.
    Port: pinion seal failed.......a month later, upper
    gear set bottom gear chunked out, wedged between
    pinion, pushed the pinion forward, breaking the case.
    I've heard there was a bad batch of XR gears
    .....I must have gotten some
    "Out of the water" was not an issue for mine.
    I'm blaming it on the "bad batch of gears" and previous owner.
    I put 450 hrs on regular bravo's behind HP500's
    and never had any issues.
  4. #24
    My Boats:
    Join Date
    Jun 2002
    What is the height difference between a 502mpi and a 575sci?
  5. #25
    Platinum Member Platinum Member bmanafort's Avatar
    My Boats:
    2004 TS Top Gun
    Join Date
    Feb 2003
    Old Saybrook, CT
    I had an 02 42 fountain with 575s for 3 seasons. Great set of motors (one of them had a little bit of a personality) but I also had a problem with one of my xr drives. The thing would constantly lose the drive oil over the course of a day.
Similar Threads
  1. how do you shrink rap a boat
    By mikebrls in forum General Boating Discussion
    Last Post: 10-27-2006, 03:17 PM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Powered by vBulletin® Version 4.2.0
Copyright © 2016 vBulletin Solutions, Inc. All rights reserved.
Search Engine Optimization by vBSEO 3.6.1
Original Poster In Postbit provided by Original Poster In Postbit v1.0.0 (Free) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd. Runs best on HiVelocity Hosting.
