Ouch! How common is this failure
JC Performance Engines
Re: Ouch! How common is this failure
did the boat sink while running?
how long was it under for?
could be a good candidate for a redo, if it can be bought cheap.
Geronimo36
Originally Posted by Viper31
Is the bell housing beefier in the HP Transom assy or just a heavier gimbal ring? I know the bell housings have different part numbers between the two. Where is Marc from BAM, he would know?
Sure looks like it's still a nice boat. Doesn't appear to have any problems with the hull. Hopefully someone filled the motors up with diesel or pickled them.
That's all I need.... another project.
Ive seen it happen twice, on two different boats. Once was a Chapparel in the Ohio river that hit a log, and one was in the winter at Lake Cumberland on a 30 Outlaw that hit a log.
Do NOT do any high performance boating near logging camps!
How does it sink???
I can see if the gimble breaks and pulls the drive shaft out of the gimble theres a big hole . But if just the belows breaks and the shaft stays in .there will be just a slow leak.
Am I missing something???
stormrider, I was standing there when they brought it up, took a couple of hours dont know how long it was down for. Did hear that it was also in need of a fuel tank replacement due to leak. When the boat was pulled it sits just like you see it in the pictures. For some better info I would ask the guys in Brick NJ about it for it was at a local marina there.
Looking at the gimble picture, it also has the 'repair in situ' plastic plugs in the sides of the transom casting, so someone has done work on this, and not wanted the extra work of removing the motor and gimble to do it.....not a good sign.
I wouldn't want a repair done to the top pin/tiller, or any major part of the gimble without having it on the bench so you can do a proper job. It really aint that much extra work for such an important part of the boat!.
Just my humble opinion.
Geronimo36
Originally Posted by Strip Poker 388
How does it sink???
Even if the drive shaft pulled out they still had the other motor and could idle back in. Once the boat is moving forward no water would be comming thru the opening and they would have had plenty of time to get to a launch ramp/marina etc. What about bildge pumps???
I had a twin alpha boat that threw a u-joint. knock out the bellows and busted up the bell housing. when i stopped to see why my engine shut down, water was coming in. I was 30 miles from the ramp, I turned on the bilge pump and had everyone go to the front of the boat. Got it on plane, and im sure it was hard on it, but got it back to the ramp at ~30mph. The bilge pump shut off once i got going. A single engine would have sank, but thats what that extra engine is for sometimes.
