Bravo Question For The Pro's
After hitting some boat shows, I noticed that the newer Bravo is sporting a new top cap with fins on it. My question is: Will this new Bravo finned top cap retro fit to the old style Bravo flat top cap? What about my old hydraulic steering fitting on top of these new caps? Would you be able to use the old hydraulic steering top bracket or is the hole pattern & clearance totally different??? :confused:
I figured someone on here has already dealt with this, any info you have would be greatly appreciated! Thanks WT |
Re: Bravo Question For The Pro's
You'd probably have better response to this thread in the Technical Q & A section. (More gearheads hanging out)!
Thanks, I'll post it there
NO, the newer caps mate to a different bearing assembly.
Thanks Guys!
Does anyone know if I were to get the newer drive with the newer top cap would the bolt patterns and spacers from my current hydraulic system still work??? |
