exhaust hose question ???
Should'nt my bravo have a flex hose from the pipe through the drive to the prop? It is on a 1997 24 outlaw 502 with captains call?
Are you talking about the exhaust pipe coming out of the transom assembly and then connects to the fitting on the drive? If that is what you are talking about no hose is required.
Look to see if the water comes in around the seering arm. Both of my drives leak water in arround the steering shaft but only when I pull the boat up on the beach. This puts the top of the drives below the water line.
