Bmax new drive sneek peak! >
Old 02-12-2006, 01:58 PM
Rob
Strip Poker 388's Avatar
Default Re: Bmax new drive sneek peak!
B Max
Attached Thumbnails Bmax new drive sneek peak!-b-max-780.jpg   Bmax new drive sneek peak!-b-max-lower-2.jpg   Bmax new drive sneek peak!-bmax-4.jpg
Strip Poker 388 is offline
Old 02-12-2006, 02:05 PM
Rob
Imco 22"
Ours 19"
Square inches of running surface:
Imco 143 square inches per side
Ours 123 square inches per side
B-Max has 40 square inches less running surface total.
Old 02-12-2006, 02:17 PM
AKA NoMoBoatin
Did you have to do any extra work to the transom like glass work,swim platform or any work at all when you installed your Bmax drives?
docmanrich37 is offline
Old 02-12-2006, 02:23 PM
The Bmax will bolt right on to a Bravo gimble. Or you can use the Bmax transom assembly which uses the same bolt pattern as the merc unit.
Maritime_Eng is offline
Old 02-12-2006, 02:34 PM
Rob
Its the same as a bravo.Easy
AKA NoMoBoatin
Thanks.I'm going to talk to Dean at the show this week.
Donzi38ZR
06-03-2008 09:59 PM
Donzi38ZR
Donzi
1
06-03-2008 01:44 PM
Ironmanwb
Baja
4
09-11-2005 11:59 AM
Buddy OO
07-13-2004 10:30 PM
Riverrunner
04-27-2002 12:37 PM
Quick Reply: Bmax new drive sneek peak!
