Quote:
Originally Posted by ReggieRaft
Did you need to modify the transom? Does it use existing holes?
The only thing I had to do was change gimbal bearings over to the XR style bearing, then set up the steering because it uses a different wing plate. You can either get longer steering rams, re-position the rams on the back of the boat, shim the rams out or leave it the same.
If you leave it the same you're going to loose some steering radius.
