If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Follow us on Facebook Follow us on Twitter
Page 7 of 7 FirstFirst ... 567
Results 61 to 63 of 63
  1. #61
    My Boats:
    40 SKATER
    Join Date
    Sep 2007
    Quote Originally Posted by Brad Zastrow View Post
    Shift those transmissions all you want. The default is second gear.The soleniod holds it in first gear, if it fails it goes to second (high) gear. I did a lot of research with the company and hi-perf transmission rebuilders. I say run them. If they blow replace them.
    How the heck do you guys know how big those engines are???
    Anybody want to guess what these are?
    Merc 525 SCs
  2. #62
    VIP Member VIP Member LubeJobs42's Avatar
    My Boats:
    44 MTI 39 MTI 35 MOTION 16 DONZI
    Join Date
    May 2002
    Fort Lauderdale
    Nice looking boat. Don't even bother shopping insurance with the normal sources. Call Elton Porter Insurance Agency in Texas 713-772-2991. I am in Chicago and they helped. The policy is with Markel American.
    Those B&M transmission are really a trick piece when they work. Big warning though. BIG!!! The transmission must be aligned perfectly or you will blow the pump in about 30 seconds. Very, very expensive fix. The crank shaft must be centered in the bellhousing. Have your engine builder do this. Adjustment is done with offset dowel pins. Since you are discussing pulling the engines make sure this is done when reinstalling the transmissions. The first gear is really only for low speeds as it is a low ratio gear. I shifted at around 40 mph. Pull back on throttle, shift and go. The boat would plane off really, really fast with low gear. Those transmissions are a problem with 1000hp. 575ci and blowers you are probably at the limit. If you blow a transmission replace them both with Hubers or Bams. I lost two of them before I gave up.
    Cats sit on top of the trailer not in it like a vee, so you will not hit the drive guard when launching. The back of the boat floats up some when launching as well.
    Lose the second wheel. Looks weird and could be dangerous.
    Brad, Tell us how you are such an expert with these trannies! How do you know they will blow in 30 seconds if not aligned?
  3. #63
    Registered Brad Zastrow's Avatar
    Join Date
    Jun 2001
    McHenry, Illinois
    Goldman and I blew one in the 35 Motion in about one minute at speed. This is before I bought the boat from Larry. Larry fixed it and it blew again. Turns out we found out it needed to be aligned.
Similar Threads
  1. Replies: 20
    Last Post: 08-05-2006, 08:07 AM
  2. New boat-questions
    By Brian C in forum Donzi
    Last Post: 12-05-2005, 04:42 PM
  3. OSO a couple of questions about the new site
    By boatme in forum General Boating Discussion
    Last Post: 05-17-2004, 03:53 AM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Powered by vBulletin® Version 4.2.0
Copyright © 2016 vBulletin Solutions, Inc. All rights reserved.
Search Engine Optimization by vBSEO 3.6.1
Original Poster In Postbit provided by Original Poster In Postbit v1.0.0 (Free) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd. Runs best on HiVelocity Hosting.
