Experience Pulling 40'+ Boat
Re: Experience Pulling 40'+ Boat
Originally Posted by Andy01
http://www.chevrolet.com/silverado/specifications/
To the jackass that said "cheap" and the other Mechanic guy that posted above that "knows" how to tow. Looks like the two trucks are pretty close even with the daul tire.......... but the single tire is HIGHER!
Originally Posted by Byrdman
and you have the balls to give advice like you know what your talking about...
Andy01 no disrespect but dispite what the specs say when you are going around a corner with 15,000 lbs in tow and you need to stop or avoid a situation your properly rated 2500 will not give you the security or performance you will need for safety . In a cornering or panic stop situation the dual wheel application will always out perform two wheels . The question is how much risk do you want to take when you are towing a large boat on a major highway.
Rick g.
Rick g.
i'd say there are alot of other factors other than 'cheap skate blah blah" in not buying a dually, im not going to get into what ive towed, how its worked, and what i think, but man byrd, you got some issues with every towing forum out there, this used to be a page of opinion and advice, but lately OSO has been nothing more than a couple of computer confident bashers
thats right....cheap skates....don't want to be bothered with dually....to big pain...does not look cool...wife can't use it...kids..shopping...garage...only good for boat...to hard to drive...whatever....you guys always got a excuse for towing with under sized stuff.....been doing it for years......but as you can see...I am not the only one telling it like it is....imagine that!
I was worried you were going to have a heart attack at some point during this thread...
Ok.. Got a bunch of stuff covered. Yes. Just because you are withing factory or registration weights. You are technically ok. But. There is absolutely nothing wrong with over compensating when hauling. A dually will always stop better and handle corners and sway better. Even a level load will sway when you get a crosswind. The insurance stuff is important also. Make sure every aspect of your tow setup is properly rated. From the hitch, reciever, and ball. Check the load rating on all of them. Im willing to bet people have under rated balls or recievers and dont even know it. The same size ball can have different tow ratings due to shank size.
Important part here folks. Sit up and pay attention. If you are overweight when towing and get stopped by DOT, you WILL face serious fines. You will also be looking at the dilemma of dropping the trailer where ever you are at and coming back with a vehicle that is properly rated to tow it. If not, you could be looking at getting arrested. The other thing. If you are involved in an accident while towing a trailer that is overweight and someone is killed. Even if the accident is not your fault. You will be looking at manslaugther charges. They will not play around on this one. You are responsible for what you are towing and that its not over the limit of your vehicle. Claiming ignorance will not work. And like mentioned before. Take into account the added weight of Gas, water and other stuff. Hope this helps you make your decision.
Flash E, In just my opinion, Ive driven over the road for 29 years and have seen alot of bad accidents. A dually can be a pain in the gas around town but you get used to it . I dont have a boat anywhere near what you have but i have a dually.Anytime you can have the added safety for basically pennies you will be far better off. I have allmost 3 million miles driveing with no accidents, but i have seen so many people get hurt by nothaveing the proper equipment or wrestleing units down the road in a bad crosswind because the dont have the proper tow unit. At least you were on hear asking questions so evidently you had your doubts. Did you happen to think about what would happen if you blew a steering or drive tire when your pulling this boat. Safety really doesnt cost you anything, if you can do this in a resonable manner.
Not to stir the pot here, You guys with trailers over 10K gross. Technically you should have a Commercial drivers license, really you need an "A" the same as a tractor trailer, you dont need the endorsements. Do you stop at weigh stations, keep log books? This has come up on other sites with regards to people towing goose neck trailers with equipment. Curious as to what you guys do?
Also, as I was told, anything over a set weight must stop at the scales but not required to be inspected. Most of the time they will not even chase you if you pass them but they have that right to. I think the limit is 10,001 or greater you have to stop.
