ocean express
#273
Hey boot, believe me when I say that my brother and I have gone around with my dad on putting the first 49' out their with diesels in it. He had a point though, because at the last SotW, Sorcerer hurt both engines, We popped an engine on our dealer demo entry, and several other hi-end, big power boats were sidelined (cat can do blew up a #6!! OUCH!)So if you took about 10 years worth of poker running with the 49' with diesels, you MIGHT spend about what any one of the those guys (or us) spent for just that weekend. And who can put a price on the satisfaction of knowing you entering, ran with the head of the pack and finished every poker run you wanted to run?
Hey slick, I'm going to say that was when we first changed our laminate schedule (lightened it a bit) and started playing around with pre-treated balsa cores and started using some vinylester resins, so theres a good chance that your boat is right about where it needs to be.(As long as it never got super wet and was never given a chance to dry out properly, they only get heavier, not lighter!)
Later,
A
Later,
A
#275
Nick, yeah, you could be safe in assuming that weight. Whats interesting is when we were building both the 39's and 48's around the same timeframe, that they would weigh within about 500lbs of one another when rigged similarily. I guess what you lost in length on the 39' you picked up in width.
Check out www.H20performance.com I posted an ad with our new canopy 38' on it under boats for sale Express Cats.
later
A
[ 01-11-2002: Message edited by: Adam Focht ]
[ 01-15-2002: Message edited by: Adam Focht ]
later
A
#276
YOur link won't work Adam ,TAke the comma off the end of it .
I got to the site but it didn't bring up pictures ,
Adam ,I think the diesel idea is great if you can find enough power and still be light enough. What type and size diesels are you doing ?
#279
Boot, were going to run yanmar 500hp/1000ftlbs torque diesels w/ an overdrive, two speed ZF trans into our new fixed shaft drive
system.
Hey Magnum, yes, we still do the 25's on a per order basis. Email me and I'll send you any info that you need. Thanks all
A
system.
A
