If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Follow us on Facebook Follow us on Twitter
Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
  1. #11
    SOX is offline
    Semper Fi Platinum Member SOX's Avatar
    My Boats:
    '96 Checkmate 253
    Join Date
    Feb 2004
    Northeast Md.
    Re: How fast does your...
    I work on a/c for a living just not on boats. Similar but I am sure there are some special considerations taken for boats. I will try to help as much as possible.
    -Typically an a/c unit will blow between 15-20* cooler air than it's return air temperature. If you got that then I guess it's ok.
    -Again , check the return air ducts for any leaks which may be letting outside air into your air stream. A/c works on removing the heat from the air not adding cold air to the space.
    -next question would be how big is the cabin? Generally 5 to 6k btu can cool a space approximately 300 sq. feet. (12k btu =1 ton of cooling = 600 square feet of effective cooling residentially) I know this is not the same with a boat but I would guess you still don't have 200 square feet to cool so I would think it is sized ok. Now check for any places that are not sealing out the outside air, That essentially adds load and could be the cause. If it's none of that than maybe you do need a bigger size a/c. But I find it very hard to believe unless your boat is black.
    I hope this helps, Good luck.
  2. #12
    My Boats:
    2001 Formula 353
    Join Date
    Jul 2002
    Jacksonville, Fl
    Thanks for the info.....
Similar Threads
  1. 353 Fast tec how fast?
    By hauling ass-a in forum Formula
    Last Post: 01-17-2013, 07:42 PM
  2. Fast, Very Fast Video...
    By ziemer in forum General Boating Discussion
    Last Post: 03-18-2007, 08:34 AM
  3. How FAST is FAST? UNREAL!
    By Emaginashun in forum General Boating Discussion
    Last Post: 12-20-2005, 06:37 PM
  4. 24' Eliminator how fast is to fast
    By Tom Earhart in forum Eliminator
    Last Post: 10-18-2004, 08:34 AM
  5. Merc 575 SCI fast idle (too fast)...
    By Cattitude in forum General Q & A
    Last Post: 08-01-2004, 09:51 PM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Powered by vBulletin® Version 4.2.0
Copyright © 2016 vBulletin Solutions, Inc. All rights reserved.
Search Engine Optimization by vBSEO 3.6.1
Original Poster In Postbit provided by Original Poster In Postbit v1.0.0 (Free) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd. Runs best on HiVelocity Hosting.
