If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Follow us on Facebook Follow us on Twitter
Page 4 of 4 FirstFirst ... 234
Results 31 to 33 of 33
  1. #31
    Ginger or Mary Ann? Charter Member US1 Fountain's Avatar
    Join Date
    Oct 2000
    Lafayette, IN
    Re: Does fogging oil foul spark plugs?
    I've just turned the key off for the last 20 yrs and changed the oil and filter and never had any issue.
  2. #32
    Rob VIP Member Strip Poker 388's Avatar
    My Boats:
    Hustler 388
    Join Date
    Aug 2001
    Quote Originally Posted by Hydrocruiser
    This stuff is basically a light oil and an upper-cylinder lubricant that has been around for years.
    Mercury Marine Fogging Oil is my personal favorite as the chemistry is designed to displace moisture very well.
    The whole idea of fogging is that it helps protect against rust and corrosion during seasonal storage periods. Helps protect metal surfaces (cylinder walls, pistons, rings, valve guides, and intake system components) against moisture and humidity. Displaces water to help prevent damage from moisture accumulation.
    Usually 2 ounces is all you would ever use and fouling should be minimal. Often times too much is used and then fouling is a big concern..
    I am not one to use ATF for fogging...and would say to stick with a MARINE SPECIFIC fogging oil.
    Here is what is in ATF fluid...
    ATF typically contains the following components:
    Sludge & varnish control
    Prohibit oxidationAntiwear
    Planetary gear, bushing, thrust washer protection
    Friction modifier
    Modify clutch plate and band friction
    Corrosion inhibitor
    Prevent corrosion and rust
    Seal swell agent
    Prevent loss of fluid via seals
    Viscosity Improver
    Reduce rate of change of viscosity
    The only problem I see using ATF is its not sticky enough and will dissipate.And guaranteed to foul plugs.Back when i raced on methonal we put a little in to lube everything because of the methonal being dry.
    I also like the Merc fogging oil .Thats what it made for
    Boost makes up for Cubic Inchs
  3. #33
    coolrunning racing VIP Member mrv8outboard's Avatar
    My Boats:
    built myself 1994
    Join Date
    Feb 2001
    cape cod
    question are you just now changing your oil from last season?
Similar Threads
  1. Spark plugs?
    By Gordo in forum General Q & A
    Last Post: 07-28-2008, 04:07 PM
  2. Spark Plugs
    By ThirdBird in forum General Q & A
    Last Post: 05-21-2008, 05:45 PM
  3. spark plugs?
    By masi242 in forum General Q & A
    Last Post: 07-29-2006, 08:55 AM
  4. Spark Plugs
    By Rick G in forum General Q & A
    Last Post: 09-05-2003, 07:11 PM
  5. Does fogging oil foul plugs?
    By Pure Energy in forum General Boating Discussion
    Last Post: 05-08-2003, 05:31 AM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Powered by vBulletin® Version 4.2.0
Copyright © 2016 vBulletin Solutions, Inc. All rights reserved.
Search Engine Optimization by vBSEO 3.6.1
Original Poster In Postbit provided by Original Poster In Postbit v1.0.0 (Free) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd. Runs best on HiVelocity Hosting.
