Static Electricity.
Re: Static Electricity.
Originally Posted by Iggy
InXS, how do you electrically ground the tank/hose prior to pumping fuel into the boat?
O.K.
Preasurizing the tank the way I stated above is a bad idea - I'll stop being so lazy and dumb. Is there anyway to pump gas from a gas caddy other than using old fashioned gravity. Maybe a hand pump that doesn't pressurize the tank?
Bryan
Bryan
Originally Posted by yss
O.K.
Bryan
Bryan
InXS, Your only half way there in grounding the tank to the truck. The tires on the truck/trailer will isolate it from the earth. The tires will generate static as it drives down the road. You need to ground the truck/trailer to an electrical earth ground before discharging fuel.
I used to work a general aviation airport pumping fuel. We grounded the fuel truck first to an earth ground, then attached a ground wire from the truck to the aircraft. The fuel hoses had ground wires built in too like yours.
