Hardine Marine sand strainer >
Old 02-14-2010, 07:04 PM
Default Hardine Marine sand strainer
Has anyone used this
http://www.keitheickert.com/detail.aspx?ID=6659
Harine Marine Sand stainer in conjuction with a regular sea stainer?
does it work well together as a pair?
cbudge is offline
Old 02-14-2010, 07:57 PM
Wink
I don't think you would want to use a sand strainer in conjunction with a regular strainer on a big engine as the water would probably be restricted to much for the engines pump inlet requirement. Check with the guys at Hardin or with Paul at Pffaff, they should no that answer.
Best Regards,
Ray @ Raylar
Raylar is offline
Old 02-15-2010, 01:56 AM
The sand strainer is more for intercoolers than for the engine. I have used them several times on intercoolers and they work great for that. I would stick to a standard strainer for the engine.
Eddie
Young Performance is offline
