Horsepower......what does it mean? >
Old 06-23-2006, 10:42 AM
PhantomChaos's Avatar
Default Horsepower......what does it mean?
I was watching a show lastnight about horsepower, and what it is and how it came about. What do you think it is?
PhantomChaos is offline
Old 06-23-2006, 10:47 AM
A to Z
Sean H's Avatar
Default Re: Horsepower......what does it mean?
it is lifting 33000 lbs one foot over one minute of time....
Sean H is offline
Old 06-23-2006, 10:48 AM
CigDaze's Avatar
Modern Marvels? Good show!!
It started as a marketing phrase.....how else do you sell someone an engine to replace their horses without knowing how many horses you can replace?
CigDaze is offline
CigDaze's Avatar
Yep. Work/time
CigDaze is offline
gotime34's Avatar
I'd have to pull my engineering books back out...but something about foot pounds.
Horsepower is defined as work done over time. The exact definition of one horsepower is 33,000 lb.ft./minute. Put another way, if you were to lift 33,000 pounds one foot over a period of one minute, you would have been working at the rate of one horsepower. In this case, you'd have expended one horsepower-minute of energy.
gotime34 is offline
Old 06-23-2006, 11:02 AM
UNSANE's Avatar
Didn't James Watt come up with the original idea for the measurement? The same man whose name Watt is used for the electrical measurement of Watts? I notice in Europe, they rate cars' output in kWatts instead of horsepower. I wonder how history would of unfolded if a different animal was used as a basis instead of a horse? Such as a Buffalo/Bison? hmmmm......or even a Water Buffalo???? Or Ox????? How would it sound to have a car commercial like this???? "The new Dodge Hemi!!!! With 400 angry Bisons underneath the hood, a 0-60 time of 1.4 seconds while towing up to 45,000 lbs, you'll have the biggest balls of them all!!!!"
UNSANE is offline
Old 06-23-2006, 11:06 AM
SORE MEMBER
Wobble's Avatar
Yes
British horsepower
The unit of power in the British engineering system, = 550 foot-pounds of work per second = 33,000 foot-pounds per minute, approximately 745.6999 watts. Abbr. hp. and abbr. B.H.P.
Origin of the British horsepower
Having invented a practical steam engine that turned a shaft, James Watt needed a way of rating the power of engines so that customers would know what size to buy. (The earlier reciprocating steam engines were only used to drive pumps, and their output was satisfactorily described in millions, which was the number of millions of pounds of water the engine could lift 1 foot through the burning of 120 pounds of coal – a unit of “duty,” i.e., energy efficiency.) The most natural way of rating the new engines was to compare them to the horse, since most potential customers were currently getting their shaft power from horses, and certainly knew how many horses were needed to do the job. Smeaton and others had already used such a comparison.
The horsepower was first defined in print in the Edinburgh Review (January 1809), in an article that suggests that the value of the unit was set through experiments Watt conducted with dray horses. In James Watt and the Steam Engine (Oxford, 1927), H. W. Dickinson and Rhys Jenkins point out that this is probably not so. Among Watt's surviving papers are his “Blotting and Calculation Book 1782 & 1783.” In an entry made in August 1782 he calculates how large an engine would be needed to power a paper mill currently powered by 12 horses.
“Mr. Wriggley, [the owner's] millwright, says a mill-horse walks in 24 feet diar and makes 2½ turns per minute....say at the rate of 180lb p. horse.”
The 180 pounds is an estimate of the force exerted by the horse. From these figures, using a value of pi = 3, Watt calculated the power of 1 horse at 24 × 3 × 2 1/2 × 180 = 32,400 foot-pounds per minute.
So the figures on which the definition relied appear to have come not from experiment but from Mr. Wriggley and perhaps other millwrights, men whose profession was designing and building factories. The job required a very good idea of the power output of horses; without it the millwright's factories would not work and he would not obtain new commissions.
Watt used the same value later in the notebook, but under September 1783, the value is changed to 33,000. A number of considerations may have led to the new value. Using the same figures as in August but with two more decimal places for pi would have given 33,912 instead of 32,400, but Watt would want a number easily used in calculations. A multiple of 60 (minutes) would be especially attractive. Further, by choosing a value that was larger than a real horse's actual output, Watt was following the old engineering principle that it is better to be too big than to fail. Steam power was new, potential purchasers were skeptical and installations that failed were more likely to be noticed than those that performed as planned. All of which suggests that the choice of the value of the horsepower was essentially a back-of-the-envelope estimation.
In Watt and Boulton's factory the word “horse,” not “horsepower” was used, e.g., a “10-horse engine.”
Modern measurements show that the average horse can put out about 0.6 horsepower through an 8-hour workday. This is consistent with Watt's desire to rate his engines conservatively.
Wobble is offline
Old 06-23-2006, 12:04 PM
HayJay's Avatar
I like it!!
HayJay is offline
Old 06-23-2006, 07:50 PM
TiVO every show!
Old 06-23-2006, 07:53 PM
Hydrocruiser's Avatar
Arrow Re: Horsepower......what does it mean?
Horsepower is a way to compensate for a small penis.
Hydrocruiser is offline
hammer_34
14
09-12-2004 09:09 PM
fountain fever27
8
03-13-2004 09:44 PM
Dock Holiday
3
10-10-2003 01:37 PM
Pat McPherson
Superboat
2
10-07-2003 11:37 AM
KNOT-RIGHT
44
06-11-2003 08:12 PM
Quick Reply: Horsepower......what does it mean?
