If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Follow us on Facebook Follow us on Twitter
Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
  1. #11
    Join Date
    Jan 2005
    Neither here, nor there
    Re: best type of concrete for garage floor??
    That place looks like a firehouse! -very nice!
  2. #12
    AT Cult Member #3 VIP Member R Addiction's Avatar
    My Boats:
    '99 Active Thunder Tantrum
    Join Date
    Oct 2000
    Thanks, Not ours yet!! 2nd floor=1700 square foot 2 bedroom apartment with a view!! This is being built on my mother in laws property by my brother in law and will house my mother in laws mother Got that? (and my AT) When my Mother in law retires we're buying the house til then it's a bad azz storage place for my AT.....with heated floors!!!
  3. #13
    Registered User
    Join Date
    Oct 2003
    The issues aren't so much additives, etc. It's quality of materials & installation. First is thickness. 4.5" would be the minimum I'd pour. Mine is 6". Next is the prep. Most concrete cracks because of settling. You need to make sure your site prep is flawless. Your contractor probably wants to get in and out. You need lots of deep compaction and that takes time- especially close to the foundation. Next is material. Specify 4,000psi concrete and require certification from the supplier. Tell the contractor you need a cured sample (this indicates you'll be having it independently tested) This will help ensure you get what you bought. If you do all this, you'll have a strong, durable floor.
    The downside of in-floor heat is that you have a big challenge locating ther tubes if you ever need to drill the floor to mount something- like a lift.
  4. #14
    Registered DONZI's Avatar
    My Boats:
    Join Date
    May 2002
    More Garage info here also.
    A forum section on flooring in there.
  5. #15
    Registered Anarchy Powerboats's Avatar
    My Boats:
    Join Date
    Jun 2004
    Phoenix, Havasu, Newport
    Quote Originally Posted by Perfectmix
    You want to go with a 3500psi(5.5sac)mix. Grade should be 4"-5" this is plenty for your application. Because you have freeze thaw I would recommend that they use crushed limestone. Instread of Natural round stone. It should only cost you a couple bucks extra per yard.(or meter for you canadians) Order your concrete with residential fibermesh. Don't use wire unless you have to, or you decide to install infloor heat.
    As far as the styro-foam, well that stuff is a PITA. If you are going to heat the building ask you local Lumber Yard of Redi-Mix plant for a product called Insul-tarp instead of styrofoam. Is is much easier to deal with and the R-factor is little better. Plus it is cheaper than styro.
    If you are pouring an approach on this building make sure that it is a 4000psi(6sac) mix. Again crushed lime stone and make sure you seal it.
    I live in N. Michigan and winters are tough here also. Concrete really takes a beating in the winter. Make sure your contracrtor or you don't wet the chit out of the concrete prior to pouring and never spray water on top of fresh concrete to help finishing. It will lead to future problems. PM me if you need any info. Good Luck
    Yeah, what he said.
Similar Threads
  1. Garage floor help
    By Tantrum in forum General Boating Discussion
    Last Post: 11-20-2003, 09:38 PM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Powered by vBulletin® Version 4.2.0
Copyright © 2016 vBulletin Solutions, Inc. All rights reserved.
Search Engine Optimization by vBSEO 3.6.1
Original Poster In Postbit provided by Original Poster In Postbit v1.0.0 (Free) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd. Runs best on HiVelocity Hosting.
