How long do you spend at the pump?
Re: How long do you spend at the pump?
Originally Posted by sakoutis3
I spend way to much time at the pump. Probably at least a half an hour. I'm usually pumping 250 gallons at a time. Always with two nozzels going. The sucky part is the locks have been removed so you gotta hold em the entire time. The worst part is paying $1200 to fill it up.
They work great when pumping gas.
Location: Lakeway, TX (Austin/Lake Travis) / LOTO Gravois Arm
Also do all of the pumps around you kick off at $50 or $75 when you try to pay at the pump? What a pain in the AZZ.
Registered User
What use is "pay at the pump" when you have to go inside to get enough fuel. I replaced the stock tank on my Super Duty with a 40 gallon tank so $75 doesn't do crap.
Originally Posted by Panther
20-30 minutes I'd have to guess, that doesn't include the 20 minutes waiting for the guy with the 51 OL taking up the whole dock to move outta the way....
Watch it.
Watch it.
When I had by boat built I had NT put 2 fill pipes on each side. Have actually pulled up to a station and have 2 pumping in each side. 450 gallons in 20 minutes and I'm on my way.
Bob
waay too long, then again there are only two pumps at the marina i go to on the lake and not to mention.....only pumps 89. the lake is down 11 feet and i cannot get the boat off the lift and onto the trailer to get 92+ right now so gotta make do. Are the Merc 8.1L 496 mag ho's safe to run on 89, because i really dont want to have to dock the boat until the get rain
Originally Posted by Bobthebuilder
Have actually pulled up to a station and have 2 pumping in each side. 450 gallons in 20 minutes and I'm on my way. Bob
Always WAY over an hour. My tank is only 140 gallons, but the fastest I can set the nozzle is on the lowest setting, otherwise, it sprays back. It's like this from start to finish.
Acording to mercury marine your engin is desighned to run on 87 octain.
