HP500EFI What oil?
Re: HP500EFI What oil?
i am running 30W quaker or pennzoil (they are basicly the same company) change it about every 20 hours, i cheat and do the filter every other change. I use an AC delco filter premium brand and a fraction the cost of mercury.
i also believe in filling the engine so it is just over the add line, less less resistance for the crank to run thru and less chance of foaming. my two cents
Thanks for the info, I usually have the marina change the oil on this boat because its easier for me. They say they use the merc oil but I want to be sure whats going in there from now on.
I was wondering about the synthetics as I heard in the past they hold up better to higher temps ect.
I dont put many hours on the boat usually 50 - 80 a year but now I am doing more trips and want to change the oil more frequently and with the same oil every time.
Thanks everybody
Thanks everybody
Ray
Ray
Originally Posted by Strip Poker 388
I been running the Valv 40 for 16 years in different boat blower motors and have never had a bearing problem or oil related problem
Thats because AC does not make the merc filters Wix does...and Wix makes a much better filter then AC does
Just my 3 cents
[QUOTE=Strip Poker 388]Guy's He admits ,Since he doesn't change the oil religiously I doubt he will buy synthetic.
I was thinking the same thing! I also would never post something like that here especially when the boat in question is in the classified!
Originally Posted by Sydwayz
Wix Racing 1061R direct from Napa. Best filter you can put on a 500EFI.
(1060R for the 496Mag/HO)
Wix Racing is very good if you want a heavy case that won't blow and a good filter too.
K&N is very good.
Fram Racing is about the only thing I see on racing engines these days...
I am very surprised everyone has not gone to a PAO synthetic oil...the data is in...it is superior...
