Looking for info on "Competitive" brand triaxle trailer >
Old 08-27-2006, 11:15 PM
Default Looking for info on "Competitive" brand triaxle trailer
I have a 1996 tri-axle "Competitive" brand boat trailer, can't figure out how to prohibit the brakes from coming on when back it up. There is some sort of spring lever underneath, also a pin on a safety wire, but have yet to figure out how to work it. I can see some sort of shaft underneath in the hole where this pin might be able to go, but the shaft extends past the hole, so the pin can't be pushed up through it. I was thinking that this might be some sort of parking brake? Not sure. Anyone have any ideas on how to lock out the brakes in reverse?
cloudmaster_321 is offline
Old 08-28-2006, 12:41 AM
biginches's Avatar
Default Re: Looking for info on "Competitive" brand triaxle trailer
pin goes in coupler, pull boat forward with out hitting brakes to expose hole.
normally they use an inline solinoid like a line lock
electric
manual valve
biginches is offline
Old 08-28-2006, 10:26 AM
Forum Regulator
Sydwayz's Avatar
Received 1,193 Likes on 518 Posts
http://www.championtrailers.com/index.html#
They also carry the Reverse Solenoid. It has to be wired into a 5th (typically blue) wire from your tow vehicle. This wire is hot when your reverse lights are on as your vehicle is in reverse. It will block the surge coupler from pushing fluid back to the brakes.
IF you live in a very hilly area, or have issues with this setup, you may need to modify your master cylinder to allow for a Bleed Around setup around the solenoid. Meaning, if you are often going downhill, your brakes will drag and overheat. The bleed around setup will allow your brake pressue to relieve on downhill grades.
Sydwayz is offline
Old 08-28-2006, 10:30 AM
21 and 42 footers
t500hps's Avatar
I switched my last trailer from a blocking solenoid to a bleeding one. Got it from Champion for about $50.00. Works GREAT!!!!!
t500hps is offline
Old 08-28-2006, 12:15 PM
so are you guys saying that i have a reverse lock out now, i want to know how to use it first before buying something else??
Old 08-29-2006, 07:52 AM
Is this company still in business? Would like to contact them to figure out this reverse lock-out if they are.
Old 08-29-2006, 02:12 PM
birdog's Avatar
You never said....Disc brakes or Drums ?
birdog is offline
Bobthebuilder
Ft Myers Offshore
2
11-03-2007 02:20 PM
offthefront
12-24-2004 03:08 PM
Hydrocruiser
10
09-21-2004 08:54 PM
BigSilverCat
03-27-2004 04:40 PM
mikesufka
12-26-2002 11:23 AM
Quick Reply: Looking for info on "Competitive" brand triaxle trailer
