Beep, Beep, Beep?????
Old 09-05-2006, 09:41 PM
fatdaddy's Avatar
Question Beep, Beep, Beep?????
I have an '03 33 Baja Outlaw w/ 496HO's. While running pretty hard in the ocean in 2- 4 ft. had the whistles come on. Checked all gauges, all fine and immediately shut down. Turned batteries off and checked all fluids, all good. Turned batt.'s back on and off I went for another 1 hr. and on it came again. Followed same procedure and all was well? I guess again. Ran the boat again this past weekend and same thing happened. Any ideas? TIA.
fatdaddy is offline
Old 09-06-2006, 07:20 AM
Default Re: Beep, Beep, Beep?????
Could be the CO monitor. Try pushing the test button. Mine beeps periodically.
Loan Ranger is offline
Old 09-06-2006, 07:29 AM
water pressure sensor.....
SLINGSHOT is offline
Old 09-06-2006, 07:31 AM
OSO Moderator
BillR's Avatar
Outdrive oil level sensor.
I rough water, mine sometimes beeps.
BillR
'00 Scarab Sport 302 CC
'02 Cigarette Top Gun TS
'02 PQ 340
'00 PQ 280
'98 Scarab 22
'97 Baja Outlaw 20
'72 Checkmate
'65 Glastron
BillR is offline
Old 09-06-2006, 07:51 AM
CAP071's Avatar
Stay out of the Ocean
CAP071 is offline
Old 09-06-2006, 08:52 AM
wrinkleface's Avatar
On a Formula I had, the bilge pump under the cabin entry step "it was stuck on". There is a little button to push or slide to get it "unstuck"! good luck
wrinkleface is offline
Old 09-06-2006, 09:10 PM
fatdaddy's Avatar
It is not periodic. I've heard what you are referring to at home in a battery operated CO monitor. Thanks anyway.
fatdaddy is offline
Old 09-06-2006, 09:11 PM
fatdaddy's Avatar
Hey Mike, I don't think so, water press. gauges indicated good pressure. Any other ideas?
fatdaddy is offline
Old 09-06-2006, 09:13 PM
fatdaddy's Avatar
I thought same thing. Shut down and checked, all good. I should note that the last time out w/ this occurrence was in flat water.
fatdaddy is offline
tomtbone1993's Avatar
fuel sensor??? for fumes??
tomtbone1993 is offline
Quick Reply: Beep, Beep, Beep?????
