Need Your Opinion - Marine Engines Inc - 1800runsnew
Re: Need Your Opinion - Marine Engines Inc - 1800runsnew
Dang, good I read this post. I was just about to buy 2 performance bbcs from this outfit. Thanks for the info, hopefully they will see things your way. I'll be watching the progress and hoping for the best. I have heard they produce a good product but now I am on the fence.
BT
BT
I purchased a bbc from this company and I have about 160 hours on it. I believe he sells quite a few engines, they are bound to have some bad units. Trust me I would be pissed if this happened to me. I hope everything works out.
I remember reading your posts about profile boats a few months back before my old account expired. This sounds a lot like same song different tune. My advice would be to try to work it out with 800 runs new because at the rate you're going there's probably not going to be a lot of companies left in the industry who are going to want to risk having you as a customer.
Sounds like you tried to do everything right, sorry about your bad luck, I hope you can get them to do the right thing!
Originally Posted by Skullkrusher
Jayhawk is right, you have had a lot of bad luck.
While this is bad enough, I am only going to be out about $3500 after all it said and done, and while that is some money money, it is not enough to change my life or something...
After this is all said, I have gained a lot of friends who are very high end engine builders, machinist, failure analysis, and just general boaters who have really helped a lot, and taught me a lot.
so yes, it is a very bad run of luck, but I think the guys who helped out would be quick to say I was VERY careful with the analysis and failure determination, and even ask their advice before posting this. This is not a customer who is a screaming, raving maniac, it is a guy who get screwed and is bringing it to everyone else's attention, just like I hope you would....
when it was profile, I was a screaming, raving maniac....
any good engine guy can have an issue with one of the motors he builds...its what he does when a problem comes up as it did here. his reply was fuk you pal, sue me and i'll make it as expensive as possible. i would pay someone the bust this asswipe up. i'd get with your credit card co asap have them reverse the charges and tell him to get on his horse and pick his other engine up!
I have a 502 from them with several hundred hours on it and never a problem. I haven't even changed the oil on it in 2 years and about 150 hrs and still runs great. I have tried to break it by not maintaining it and still no problem.
Sorry about the use of the word luck,sounds like the engin was doomed when the builder put the last bolt in.
