Used boat values and engine hp >
Old 09-22-2006, 09:11 AM
BY U BOY's Avatar
Default Re: Used boat values and engine hp
IF YOU ARE SELLING USE THE HIGHER HP.
IF BUYING USE THE LOWER HP #
BY U BOY is offline
Old 09-22-2006, 09:14 AM
cosmic12's Avatar
don't depend on N.A.D.A. most banks or dealers don't use it. They use A.B.O.S.
cosmic12 is offline
Old 09-22-2006, 09:22 AM
onesickpantera's Avatar
I'm just using NADA as a guide. None of the books are a "Bible". ABOS uses hoices for hp too.
FYI, my bank uses NADA and most of our local banks do as well.
onesickpantera is offline
Old 09-22-2006, 09:28 AM
Good point!
Old 09-22-2006, 09:33 AM
Actually, the majority of my lenders look to the NADA for loan values; and they work off of the "used trade-in $#". If there's no data in NADA, they will default either BUC or ABOS. ABOS doesn't quantify any option costs, but they do better with motor hp ratings, using actual $ values for the various engine packages that were available in that hull. The HP500's and 500EFI's value @ 470 hp, 525SC's value @ 490, and I believe 525EFI's value @ 500.
hpoffshore is offline
Old 09-22-2006, 09:51 AM
Thanks for the replies but now I am more confused than ever!
The reason for this question is I am trying to determine how much more a used boat would be would be worth with an HP500EFI compared to a 502 Mag EFI.
Old 09-22-2006, 10:42 AM
It would be the $ difference between the boat with 470hp and the boat with 415 hp. As I said, ABOS gives you the actual $ of the boat with that particular motor/power; NADA has a $ chart for the upgrade from the boat with base hp, to the upgrade horsepower that YOU specify. You can access NADA online(BUC, too). If you want ABOS $'s, I'll be happy to run them for you. PM me.
Old 09-22-2006, 11:11 AM
No need for that at this time but I appreciate your offer. I may take you up on it later.
NADA just emailed me back and said to use CRANK HP. But, the more I look at their site the more that doesn't make sense. "Standard motors" are popping up at 385hp a lot which we all know is a 454 Mag MPI.
Old 09-22-2006, 11:15 AM
Exactly..........
DURANGOKID59
08-24-2008 01:11 PM
rangerrick63
01-05-2007 11:10 AM
born2burn
04-17-2005 10:16 PM
Tantrum
08-13-2004 11:02 AM
Steve_H
01-29-2003 03:59 PM
Quick Reply: Used boat values and engine hp
