New Engines: 557 or 572
Old 10-17-2006, 10:00 PM
  #61
GPM
Default Re: New Engines: 557 or 572
Felpro 1077, 32 on 114 octane. and 12lb of boost.
GPM is offline
Old 10-17-2006, 10:06 PM
  #62
44MTI's Avatar
Originally Posted by JCPERF
6300 to 6500 with real roller lifters
What rod lenth is that, and is it the same as a Merc 900 or sterling 1050. Trying to stay with the conventional head stuff.
44MTI is offline
Old 10-17-2006, 10:16 PM
  #63
JCPERF's Avatar
6.635 is a good rod length for that combo
JCPERF is offline
Old 10-17-2006, 10:32 PM
  #64
PF Marine
Coolerman's Avatar
904 or bigger
those work great for us!
Coolerman is offline
Old 10-17-2006, 10:33 PM
  #65
JCPERF's Avatar
That with a good Isky tool room gold stripe spring eliminates the bullsh1t 50 hour service.
JCPERF is offline
Old 10-17-2006, 10:36 PM
  #66
JCPERF's Avatar
These 557s that make 1100HP went 178 hours since i built them with the big lifters and Isky springs.And they got murdered too.
Attached Thumbnails New Engines: 557 or 572-49499picture_571-med.jpg
JCPERF is offline
Old 10-17-2006, 10:42 PM
  #67
mikes280's Avatar
the 1077 is the mls gasket i have had good luck with them, are they leaking water or are you blowing them and if so where
mikes280 is offline
Old 10-17-2006, 10:43 PM
  #68
JCPERF's Avatar
Originally Posted by mikes280
the 1077 is the mls gasket i have had good luck with them are they leaking water or are you blowing them and if so where
Finish on the block has to be to the specs that Fel-Pro want for that gasket.It says it on the case that they come in.
JCPERF is offline
Old 10-17-2006, 10:53 PM
  #69
mikes280's Avatar
you are right just got to hope he had that right hell i like that gasket better then the cometic
mikes280 is offline
Old 10-17-2006, 11:49 PM
  #70
Rob
Strip Poker 388's Avatar
I don't like a sq or over sq motors.the thrust angle and the big slug your trying to sling..
Remember back when the Nascar guys were destroking there motors making more power.
Also why do you think Sterling is running that cube, they have people spending $$$.I bet the experimented on a few costumers I would think they figured it by now whats the best combo, again there looking at max hp in a race application and usually have a higher RPM peek hp .I would think The bigger the ci the lower the RPM.
CI cal
http://www.itpapulling.com/ci_calc.html
http://www.ajdesigner.com/phpengine/...lacement_b.php
piston speed
http://www.csgnetwork.com/pistonspeedcalc.html
http://www.thedirtforum.com/pistoncalc.htm
rod ratio
http://www.mustang123.com/calculator...Calculator.asp
Strip Poker 388 is offline
Quick Reply: New Engines: 557 or 572
