New Engines: 557 or 572
Old 10-18-2006, 06:27 AM
  #71
GPM
Default Re: New Engines: 557 or 572
Originally Posted by mikes280
the 1077 is the mls gasket i have had good luck with them, are they leaking water or are you blowing them and if so where
No water problems, just leaking between a couple of cylinders.
GPM is offline
Old 10-18-2006, 06:47 AM
  #72
Registered User
36spectre's Avatar
Originally Posted by Strip Poker 388
I don't like a sq or over sq motors.the thrust angle and the big slug your trying to sling..
Remember back when the Nascar guys were destroking there motors making more power.
Also why do you think Sterling is running that cube, they have people spending $$$.I bet the experimented on a few costumers I would think they figured it by now whats the best combo, again there looking at max hp in a race application and usually have a higher RPM peek hp .I would think The bigger the ci the lower the RPM.
CI cal
http://www.itpapulling.com/ci_calc.html
http://www.ajdesigner.com/phpengine/...lacement_b.php
piston speed
http://www.csgnetwork.com/pistonspeedcalc.html
http://www.thedirtforum.com/pistoncalc.htm
rod ratio
http://www.mustang123.com/calculator...Calculator.asp
ROB,
What would make you think that they are interested in low maintance intervals and overall motor longevity???????
Otto
36spectre is offline
Old 10-18-2006, 07:04 AM
  #73
Originally Posted by Tapa11
Are the solid rollers really worth the trouble?
They are well worth it. They are no trouble if the valve adjustment is done properly.
mrhorsepower1 is offline
Old 10-18-2006, 07:08 AM
  #74
Originally Posted by 36spectre
Due to harmonics....always build a square engine...they are happier and
they will last significantly longer
I would have to disagree with this statement. A square engine verses a oversquare has nothing to do with harmonics. If your having troubles with harmonics get a new engine builder that knows how to balance! If every component is balanced correctly and accurately the engine will have ZERO vibration in it.
Old 10-18-2006, 07:10 AM
  #75
Originally Posted by Panther
Can someone confirm or deny but I understand the 572' has a less than optimum rod-to-stroke ratio.
That depends on how long of a rod length you choose.
Old 10-18-2006, 07:11 AM
  #76
Originally Posted by ratman
572 4.5 X 4.5
This is one way to achieve 572 cu.in. ( the most common)
Old 10-18-2006, 08:52 AM
  #77
Dean what CI are these, I forgot what you told me.
Thanks Bro excellent job!
Attached Thumbnails New Engines: 557 or 572-engine-install-026-small-.jpg
customryder is offline
Old 10-18-2006, 04:16 PM
  #78
GPM
which one would hold up better 572 or 598 both with the same rod length?
GPM is offline
Old 10-18-2006, 05:44 PM
  #79
Are we taking with a 4.5 stroke on both? If so Both packages are capable to go the same amount of hours if built right. The 572 combo will have a tad better seller between cylinders due to the smaller bore diameter.If your talking supercharged I would go with the smaller bore engine for this reason. The other objective to use a 4.500-4.530 bore diameter is to allow more rebuild life in the engine and again better head gasket seal being SC. I like to build life into the engine instead of maxing out the bore on a brand new Dart Big M or Merlin block. As far as ring seal goes between the two combos, on N/A packages both will hold up the same. SC combo ring seal may go away a tad sooner with the larger bore area 598. A ton of other factors come to play with longevity as you already know.....machining, assembly,and of course tuning!
Old 10-18-2006, 05:45 PM
  #80
557
Quick Reply: New Engines: 557 or 572
