Water in oil
have a 30ft Scarab w/twin 502s. Lost RPM on port side, told I hit something...after much srambling, found upper & lower units. Installed, still didnt solve problem. had boat hauled...told trans. shot. had port trans rebuilt, starboard trans freshened. Finally ran the boat..starboard water pump let go. Had impeller replaced. ran boat again. Now, find water in the port motor! What gives? Can water get in oil during install if motor is turned? Any info would be appreciated. Thanks, Tom
Re: Water in oil
Did The Engine Over Heat? How Much Water In The Oil?
Could Be A Blown Head Gasket Of Manifold Gasket. |
Re: Water in oil
Water in the port motor has nothing to do with anything else you described unless when you lost the water pump, you overheated and blew a head gasket.
Re: Water in oil
I never over heated the engine...the guy who rebuit the trans had it running. Water is to the top of dipstick.
Re: Water in oil
It's possible that you've got a leaking engine oil cooler. That's the only way you'll get that much water in the oil. If the cooler starts leaking water, the only place it can go is into the oil, which eventually ends up back into your engine.
Pull the oil cooler and pressure test it to be sure. |
Re: Water in oil
I really hope you drained the water/oil mix out :eek:
If not, its probably gonna need a rebuild. |
Re: Water in oil
I agree with 10 x . where are you at maybe some of us can help you if needed
Re: Water in oil
Check the intake manifold and gaskets. Also, check the exhaust manifolds. Sounds like a lot of water igot in the motor. :(
Re: Water in oil
Thanks for all the tips...I had the oil changed...stored the boat untill next spring. Im in the Great lakes. Cold up here!
Re: Water in oil
If You Had As Much Water As You Say You Did. You Really Need To Pull The Engine And Do Something To Prevent Rust So You Can Use It Next Season.
Just My .02 |
