Stellings Box--Steering Questions
Hello Everyone...I'm hoping someone can give me some information.
Does anyone have a Stellings box with a single bravo setup? If so, could you find a part number or a manufacturer of the hydraulic steering rams? I'm working on a top-secret project with a friend and would love to have that info. If no part numbers...how about some specs for the steering rams for a Stellings box? Thanks in advance :) Dave |
Re: Stellings Box--Steering Questions
All the ones I have seen use std steering rams and a spacer blocks to keep the stock geometry. Joe Murray
You use the same hydraulic rams. Differernt manufacturer's have different mounting systems for the rams.
Marine machine uses an extended mount on the transom. Imco has various setups that mount ears on the box and/or the drive. This AT has Marine Machine steering with Stellings boxes. Its twins, but the set up is the same as what would be used on a single. http://www.offshoreonly.com/esvon/page-10933.html |
2 Attachment(s)
have the set up and it works just fine
