Cat Length question
Theoretically, shouldn't a 38' Cat be able to pack more air underneath than a 37' 9" Cat assuming everything thing else is equal? I realize we're talking about a minuscule difference. But is there any reason the boat that's 3" shorter would be faster if everything else was equal?
Looking for technical responses please. No BS, No polotics. Please. |
Re: Cat Length question
Okay, I'll play. Theoretically a 37'9 1/2" boat could have less wetted surface in the water and be faster-overcoming the decrease in possible lift. Remember that most boats only have a fraction of the hull wetted-esp cats. Assuming a 2 foot wetted surface at speed the 2.5 less inches would have a much greater effect than 2.5 inches of a lift area that is 30 plus feet long. So there ya are...thanks for playing.
The width, height and funneling of the tunnel will also effect the amount/velocity of the air underneath the cat.
but to answer the question, tunnel length and boat length aren't mutually exclusive...a longer cat won't pack more air unless it has a longer tunnel....and if a longer cat has a longer tunnel, it also has more weight to lift now... kind of a viscous circle... |
I don't know where the 2.5" is coming from, whether it's the tips of the sponsons or the transom which would affect the tunnel and airfoil, but either way we're talking about a difference of 0.5%. Say it is in the tunnel area, lift and drag behave linearly with surface area as defined by L (or D)=1/2 * rho * V^2 * S * Cl (or Cd), where rho=density, V=velocity in fps, S=planer area in sqft, and Cl=coefficient of lift (or drag). Again, 0.5% differences...maybe.
After running a quick CFD comparison, I see no appreciable difference. |
Is being 3" short going to give ANY advantage? Does it have ANY disadvantage?
PS - Hello to my old friends Uncle Teddy :evilb: and Nick :drink: |
Originally Posted by Sean H
the 2.5 inches in question is overall boat length from tip of sponson to the top of the transom... there is no set length for tunnels...
Life is good.
