Hooters scl, what are the black things ?
Re: Hooters scl, what are the black things ?
Originally Posted by jtmiller02
If I am reading this correctly you are saying that pressurized air from your bilge is entering your cockpit while running? If this is the case you should contact the manufacturer ASAP to find a fix, that is a very serious safety issue. Your cockpit should be well sealed from the engine compartment to protect you from possible fuel fumes which could cause fire/explosion and also carbon monoxide. A fire in the bilge would be forced by this pressure into your cockpit at an accelerated rate.
All ventilation should carry any air from the bilge well clear of the cockpit, and optimally should be easily closed incase of a fire.
A fiberglass boat is one of the most dangerous places you can in the event of a fire, fiberglass is highly flammable, it produces toxic fumes when burned and it holds hundreds of gallons of explosive fuel...in short, when it comes to an emergency you need all the breaks you can get.
I have four 4lb. two per engine bay manual and auto Halon exstinguishers with deployment indicators on dash.
When sizing the above fire suppression system I doubled
the cubic feet on the space requirements.
I have manual fuel shutoffs in the cockpit aswell.
It is a open cockpit layout. The cabin is also open.
I am modifying the blower scoops to dump the
incoming air aswell. Actualy cutting the rear of them out.
I could also install relief ducts on the transom.
Thanks for the advice
Gerry
Rules in spec class racing do not allow for pressurized engine compartments. Since all the boats use a fresh air induction system there needs to be a way to vent any excess air out of the bilge. As far as pleasure boats it would be a benefit to run a pressurized engine compartment. It is very important to seal the engine compartment from the passenger compartment, as stated earlier.
DPT MOTORSPORTS
General Racing Discussion
14
03-25-2005 12:59 PM
dloftis
Baja
2
04-08-2002 10:53 PM
