Re: 105 mph FASTCATw/300X
Originally Posted by NoGas
(Post 1982369)
Sounds like a great boat! Do you special order these and if so how long does it take to get your hands on one?
sc dog nice and fast no doupt . but doin't jump on a allison bass boat with a 2.5 bridge port on it . . you wil be eaten by a cat killer . try 117 mph with no problem .
fountainsfan:
I am no stranger to any bass boat performance #'s. Why should't a 1400lb to 1600lb rigged Allison be that Fast... I HAD one. I will take a FAST CAT with the same rigged weight 1400 1600lbs and give it all it can handle... be right there with it.... or add 1000lbs to that Alley and run it ...that Allison isn't going to run NO 117 @2400+ lbs. .......:D |
obda
with a 150 pm it wil run 80 with a 225 pm it will run 96 to 98 and 280 will push it 117. the boat does not weigh but 975 lbs dry . it not a regular bass boat check out bwb. they have tested it. allison ownes all bass boat speed records.
there are several around here that will .
Fountainfan:
Like I said... those boats are NOT 2400+ pound rigs....:chimp: |
