Verado 300 and 325HP to debut in Miami
#51
Most any auto parts store will recycle your oil for free. The boat has to be out of the water to drain the oil just like changing the oil on a bravo outdrive.
Also you do not have to use the Mercury oil. Most all the SKA guys with Verado's are using Mobil 1 which is less than the Merc stuff.
Part of the what makes the Verado's good is the whole package as a system. The throttles and steering are car like, easy to use and work, no cable to worry about and very very reliable.
Your right it sounds much easier !
I do not have to make any special arrangements to pour oil in my VRO tank !
#52
First off I like two strokes less moving parts, less to go wrong. Fever Mike said he changes oil every 200 hours that almost a whole boating season in Wisconsin. Both the 2 and 4 stroke outboards have strength and weaknesses.
#53
I also thought the service time was 100 hrs ? Didn't someone state that earlier in the post ?
I think the Verado's are good engines (any 4 stroke), but they have some down side too.
#55
So if you have a 4 stroke you have to pay to dispose of your used oil, but with a 2 stroke you just release it into the water?
I think 100 bucks is high for an oil change, my Ford dealer only charges 89.00 to change the oil in my diesel super duty and it holds about 15 qts. They use Ford oil and they're not known to be cheap on their service. But then again I charge an hour labor to change oil in a boat plus materials, so thats well over 100.00 for a little 3.0L Mercruiser.
#56
All of us performance center console outboard guys benefit. I never thought I would see V8 outboards again
Just look at the warranties these mfg.s are offering !
Bombardiar is offering 7 years !!!!!!
#60
So if you have a triple engine Verado powered CC. You will have ( 7quarts/engine X 3 egines = 21 quarts or 5.25 gal. of waste oil ) to drop off a your local auto parts store along with 3 filters. If your boat is racked stored (maybe the 2nd or 3rd level) you will have to make arrangments to put in a service staging area. How about if you have a lift on the water. Is it possiabe to service the oil drain without spilling any in the water ??? If you can not access, I guess you spend a half of a day, loading the boat on a trailer ($possiable ramp fee) changing the oil and unloading back on the water. I don't know about the marinas around you but most marinas in the summer, let alone on the weekends are very busy.
