If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Follow us on Facebook Follow us on Twitter
Page 4 of 4 FirstFirst ... 234
Results 31 to 32 of 32
  1. #31
    Rob VIP Member Strip Poker 388's Avatar
    My Boats:
    Hustler 388
    Join Date
    Aug 2001
    [QUOTE=Locomotive Breath;2022793]
    Quote Originally Posted by Strip Poker 388 View Post
    Nope .A buddy of mine at MSD sent it to me and I posted it on a few sites,they said its not a good motor, that its going to break the stang, the motor vibrates real bad ,cranks fail alot , bad design.I posted it on speedtalk and the owner responded there , alot of engine builders there gave some pretty good info about it,
    960 lbs , the 180-degree crank is going to shake it apart.
    Average operation RPM range was 1400-1600rpm
    starter motors where 72volt and rated at 16HP
    Each piston has 6 rings on it and has MASSIVE ring drag. Plus, they weight 4 pounds apiece
    It's mine. They vibrate some between 1600 and 1900, but really smooth out around 2200, and really start singing around 4000. I know guys that have twisted them to 5200, but my rev. limiter is set at 4800. The factory starter was 24 volt, but it's history anyway. I use dual Powermaster Chrysler V8 racing starters on mine, one on each side. They are working great so far. The factory pistons use 5 rings, but you don't have to use all of the grooves, and you don't have to use stock pistons. My engine uses 4 Total Seal rings on modified stock pistons. My second engine is getting custom pistons for the 32 pounds of boost that it will see on a regular basis in my pulling tractor. These old engines will make ALOT of power when built correctly. They really like turbos due to the 180 degree cranks. I built the Mustang just for fun, I don't plan on breaking any world records with it.
    Several years back there was a guy named Bob Patterson out west that ran a GAA powered boat. The engine was basically stock except for the intake and carbs. It was very competitive with dual big block Chevy combos at the time.
    Cool welcome to the board Alot of guys on speedtalk were giving ya some shet about it on the forum. I guess your taking it farther than they know. Hope ya get it going soon. Its defiantly going to one hell of a attention getter at the local Sonic cruzes!!
    Ya got any updated Picks?
  2. #32
    Join Date
    Feb 2007
    Thanks guys. I cranked it up earlier this evening. It is a beast, shook the shop walls pretty good. The alky. fumes even cleared out my plugged up sinuses. I will try and post something on U-Tube tomorrow. I only have dial up here at home.
Similar Threads
  1. 1100 Cubic inch tank motor in ??????
    By jeff1000man in forum General Boating Discussion
    Last Post: 02-09-2007, 12:30 PM
  2. What Cubic Inch 572, 622?
    By FASTERDAMITT in forum General Boating Discussion
    Last Post: 04-27-2005, 04:32 PM
  3. 2.5 HP per cubic inch, How hard is it?
    By GPM in forum General Q & A
    Last Post: 02-12-2005, 08:08 PM
  4. 708-cubic-inch, all-aluminum engine for marine use
    By bpine in forum General Q & A
    Last Post: 08-29-2004, 08:34 AM
  5. Big cubic inch question....
    By SinkorSwim in forum General Q & A
    Last Post: 12-11-2003, 11:38 AM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Powered by vBulletin® Version 4.2.0
Copyright © 2016 vBulletin Solutions, Inc. All rights reserved.
Search Engine Optimization by vBSEO 3.6.1
Original Poster In Postbit provided by Original Poster In Postbit v1.0.0 (Free) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd. Runs best on HiVelocity Hosting.
