Cleaning your engine compartment
Does anyone have any good ideas for cleaning exhaust stains off the gelcoat in your engine compartment?
Pair-A-Dice Racing
Pair-A-Dice Racing
I would think it's from the breather hoses comming off the valve covers. Under a closed engine hatch, the air is probably filled with the crankcase pressure fumes, and after time it builds up on everything if not cleaned regularly....(especially noticable white gelcoat).
I usually cover the distributer, carb, and unload a whole bottle of simple green throughout the bilge, then carefully hose down.
Official OSO boat whore
If I recall correctly, they've had some trouble with the header bolts loosening.
Anyways, I've had good luck with simple green. You have to put it on kinda heavy and let it soak, but it does a pretty good job. Soft scrub with bleach and alot of water does the trick to the vinyl.
I use dri-wash to remove diesel and gas exhaust stains, on my boat and dads cruiser. Spray on wipe off. http://www.angelfire.com/nb/detailli...arverstern.jpg
