Your Winter Projects And Results... >
Old 04-18-2007, 06:51 AM
Single With Twins's Avatar
few more..............
Attached Thumbnails Your Winter Projects And Results...-p1020727.jpg   Your Winter Projects And Results...-p1020731.jpg   Your Winter Projects And Results...-p1020725.jpg
Single With Twins is offline
Old 04-18-2007, 08:26 AM
-Installed Sea Strainers
-Powdercoated treadplate on bulkhead
-Freshened Shortblocks
-Removed Iron GM Heads and Installed Brodix Aluminum with new cams
-Switched from 28 4 blade to 29P5X
-75mph to 82mph
Attached Thumbnails Your Winter Projects And Results...-excalibur_006.jpg   Your Winter Projects And Results...-excalibur_023.jpg
TxHawk is offline
Old 04-18-2007, 08:34 AM
GLH
GLH's Avatar
Originally Posted by 25 hors la loi
....we like it when we have some wind ...
Your Frige won't like the wind!!!
How can a Canadian afford to buy all the stuff??? Do you have somewhere where you get all that shipped in the US and then a good friend of yours gets it to you to install in your boat ????
Or What?
Boy am I glad all those freaking boxes are out of my office!!!
GLH is offline
Old 04-18-2007, 08:51 AM
25 hors la loi's Avatar
....Oups .. i forgot to say Thank`s to my friend in US
25 hors la loi is offline
Old 04-18-2007, 10:51 AM
1990 Shadow cat with twin 300PM
1-Replaced some soft wood on floor and re glass
2-Replaced a trim cable
3-Water pumps on lowers
4-Rebuilt one lower (Gears and bearings)
5-Put in a new indicator for tunnel tab
6-Built in a micro switch to tunnel tab trim indicator to limit downward travel
7-Put on Jackplates
8-Re rigged and rerouted all hoses and cables to the motors
9-Put rigging tube and bezels to make it look good
10-And this is what I am most proud of,Designed and Built my Tunnel Tab
fishead is offline
Old 04-18-2007, 10:52 AM
Pic of Tunnel Tab and Jackplate
fishead is offline
Old 04-18-2007, 11:24 AM
Just remembered
11-Replaced poppet valves
12-Installed new billet vents
fishead is offline
Old 04-18-2007, 05:36 PM
camptappakeg69's Avatar
Just writing a check for a outdrive rebuild and new gimbal ,and Bblades doing the prop....
camptappakeg69 is offline
Old 04-18-2007, 06:36 PM
Charter Member#330
MrCIG's Avatar
Looks like the heads and cam really woke them up
What Brodix heads did you use?
Mark
-75mph to 82mph
MrCIG is offline
Old 04-18-2007, 06:37 PM
ReggieRaft's Avatar
Put the boat away tuned up ,one rebuilt drive , washed and waxed. Sat around and gained a few pounds.Where is the sun?
ReggieRaft is offline
Quick Reply: Your Winter Projects And Results...
