Air shift crash boxes
So with the air shifter you don't have to shut down the motor and can shift like you have transmission?
SCS quoted me 16000 for the pair.
Dont know what comes in the kit.
But this is what you need.
Machined flywheels
Under block starters
12 volt air compressor with tank.
micro switches located in the throttles.
( I beleave they have incorperated them in the Neutral saftey
switches so you dont need them in the throttles)
SCS can answer all your questions.
There are also a coulple of used ones I have been
scoping in the neighborhood of 8000 for the pair.
The only way to go with Big power and big boats
Gerry
Machined flywheels
Gerry
Machined flywheels
Gerry
Machined flywheels
Gerry
You and I can tear up the water together in both of Gino's boats.
We all know the stories - this would probably be a much safer move for him, with his bad-luck and all.
With his luck, the life insurance premiums gotta be draining him - this would be a method of cutting his expenses.
Gino - good luck with the new boat - and remember, keep the tow vehicle dry when launching.
Speed Racer here, I have them in Big Speed (the pleasure version of Speed Racer) And they do hold up and work great, never any problems if they are set up properly. You really need to know how to work them, it just takes time, but I love them in my boat. Do it the easy way and just buy SPEED RACER, Buy the best and only cry once.
Skater Brother
I've been using them for a couple of years in Freedom US1 and they work great!!! Be sure to put switches on the dash or somewhere convenient to give you positive control over the air clutch. They have shifters available with microswitches to make it seem like your shifting a regular transmission but I have found that they don't work some times and its best to use the manual toggle switches for positive control. Its the only way to go with big power and park at poker runs.
