Trim and Tabs "popping" through the speakers.
So, new boat to me - it has a head unit, 4 speakers and a single 4 ch. 240w amp. Each time I hit the trim or tab buttons it "pops" through the speakers, can't imagine this is good for the system, not to mention irritating to me. Any thoughts as to a fix before I tear into it and search out the source. I have done systems in the past in my boats and never had this issue.
Thanks,
Mark.
Thanks,
Mark.
ground wire from the amp. To solve the problem you may need to run a heavier ground wire from the amp to your battery. The gauge of the ground should be at least the same gauge or bigger then the power. Also make sure the ground connection is good and clean. If at all possible make sure the ground wires and the power wires aren't running next to each other this can cause noise. The power and the ground cable should be shielded.
