If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Follow us on Facebook Follow us on Twitter
Page 2 of 6 FirstFirst 1234 ... LastLast
Results 11 to 20 of 56
  1. #11
    good2go38 VIP Member
    My Boats:
    Join Date
    Mar 2005
    Charles City, Va
    There is a difference in 30 degrees when you are towing or sitting still. If the boats engine compartment vents are not covered the air is being forced into the engine compartment. The area cools quickly and could potential cause a freezing problem.
    You may be able to pull the temperatures from the National Weather service for the date, time and location in question to verify that the temperature was actually 30 degrees. Good Luck!
  2. #12
    Registered H2Xmark's Avatar
    My Boats:
    1997 Fountain 35 Lightning
    Join Date
    Apr 2001
    beaumont tx
    the fiberglass hull will act as an insulator, so if the boat was in 30 degree weather, inside the engine compartment will be at least 3 or 4 degrees warmer. from the few car engine i have looked at that cracked it took lower 20's for several hours to cause this, the bad thing about boat engines though is that the bottoms of the block will have silt and mud trapped at the bottom, so if it packs up bad enough even if you drain the block the silt will hold some water and can freeze and crack the block, on your friends boat Gino sounds like someone is not being honest with you, sounds like the boat sat outside in very cold weather [below 23*] for at least 6 or 7 hours or longer[ most likely longer]
  3. #13
    Registered User
    My Boats:
    1990 28 Apache SOLD!, 1990 16 Wahoo DC, 1973 40 Kingscraft
    Join Date
    Jan 2007
    Mansfield, TX
    Sometimes when boats sit in water the ocean/lake water will keep them from freezing because the lake has not had a chance to drop that low - so it can work like a weak heater. I think that when you are moving on the highway the cool air could definately flow through the engine via the blowers and accelerate the process. Like driving a car down the highway- if its wet and its below freezing your car will likely have ice on it way before the bridges are frozen over.
    Not an expert....
  4. #14
    Registered UNSANE's Avatar
    Join Date
    Sep 2005
    Quote Originally Posted by jordy View Post
    But I'm from Phoenix where "winterizing" a boat means wearing a sweatshirt to the lake when you go in January.
    And in Florida, that means wearing pants!!!
    Seriously, something's fishy here.
  5. #15
    Registered Platinum Member
    Join Date
    Jul 2004
    atlantic city, NJ
    Possibly the owner should have winterized it prior to coming north a couple of months ago...wind chill can do it it had a way in....yes in 4 hours IF it had a way in!...who would send a boat north and not winterize it...
  6. #16
    Registered BBB725's Avatar
    My Boats:
    39 Nortech CC
    Join Date
    Jan 2005
    Wi/ Fl Keys
    Wind chill, yes it can happen
    Attached Images Attached Images
  7. #17
    My Boats:
    Join Date
    Feb 2005
    Cleveland, Ohio
    Your answer is yes it can happen. I had a Drag Racing customer that was going down south to race one year, He alos had to travel through very low 30's winter weather heading to Gainsville,Fl. I had recommended him to at least drain the water from the engine block and radiator before he leaves. He didn't and ended up getting to the race track to find a busted cylinder block! The temperatures where right near freezing also.
  8. #18
    Registered SPITFIRE's Avatar
    Join Date
    Oct 2002
    Boston Ma, Charlotte NC
    I thought wind chill only had effect on living tissue??
  9. #19
    My Boats:
    I think I have a Center Console now
    Join Date
    Jul 2006
    Ft. Lauderdale Florida & Tarpon Springs Florida
    Would have thought the freeze plugs would have popped first
  10. #20
    S.O.B (single O/B) now Platinum Member t500hps's Avatar
    Join Date
    Sep 2004
    Richmond VA
    Sitting still no way 30 degree did it.....moving down the highway, well??? I just don't know. When daytime highs are over 40 I don't sweat nighttime lows in the mid-upper 20's.
Similar Threads
  1. Mercury Tour & Crack the Ice Party sign up today
    By MarkSmith in forum Northern Illinois Offshore Club
    Last Post: 03-24-2007, 08:41 PM
  2. Free Dvd From Oso & Freeze Frame Come See Freeze Frame Video At Miami Show Booth 3988
    By FREEZE FRAME VIDEO in forum General Boating Discussion
    Last Post: 02-20-2007, 02:13 PM
  3. Block with Anti-freeze
    By gripit in forum General Q & A
    Last Post: 12-05-2005, 06:23 AM
  4. Any way to repair a freeze cracked block?
    By klmken in forum General Q & A
    Last Post: 07-17-2005, 06:26 PM
  5. Replies: 11
    Last Post: 09-23-2002, 10:26 AM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Powered by vBulletin® Version 4.2.0
Copyright © 2016 vBulletin Solutions, Inc. All rights reserved.
Search Engine Optimization by vBSEO 3.6.1
Original Poster In Postbit provided by Original Poster In Postbit v1.0.0 (Free) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd. Runs best on HiVelocity Hosting.
