If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Follow us on Facebook Follow us on Twitter
Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
  1. #11
    Registered TSPM's Avatar
    My Boats:
    Join Date
    Jul 2004
    ~ Long Island ~ NY
    496 MAG MPI - 375 hp
    Power 375HP (280 kW)
    Full Throttle Range 4400 - 4800 RPM
    Displacement 496 CID (8.1L)
    Engine Type V8
    Bore & Stroke 4.25" X 4.38" (108mm X 111mm)
    Compression Ratio 9.1:1
    Fuel Requirement 87 Octane (R M)/2
    Engine Control System PCM 555 with SmartCraft CAN Capability
    Fuel Delivery System Gen III Cool Fuel
    Fuel Injection System Sequential Multi-Point Electronic Fuel Injection
    Induction System 2-pieceLong Runner intake with 75mm Throttle Body (80mm w/DTS)
    Ignition System Distributorless Ignition w/Knock Control and Platinum Spark Plugs
    Charging System 65 Amp/917 Watt Alternator
    Water Drain System Single Point Air-Actuated
    Exhaust System Tuned Runner Exhaust Manifolds with 316 Stainless Steel Tubular Dry Joint Elbows
    Cooling System Closed Cooling, Long Life 5-Year Anti-Freeze, Brass Sea Water Pump
    Accessory Drive System Serpentine Belt, Stainless Steel Spring Automatic Tensioner
    Recommended Engine Oil SAE 25W-40 NMMA Certified FC-W
    Engine Guardian System Low Oil Pressure, High Coolant Temperature, High Exhaust Manifold Temperature, Low Drive Lube, Low Sea Water Pressure, Low Voltage, Over-rev control, Knock Control
  2. #12
    My Boats:
    Join Date
    Jul 2004
    ~ Long Island ~ NY
    Quote Originally Posted by jtmiller02 View Post
    Both have a 5 year warranty also, hop up a regular 496 with a kit of any sort and kiss that warranty goodbye. If you are shopping for new motors this could be an important consideration.
    1 YEAR MFG warranty on both motors not 5. You can pay for the extended warranty to 5 or 6 but factory is 1 YEAR
  3. #13
    Join Date
    Oct 2004
    Newbury Park, CA
    A while back I checked the replacment parts list for the 496 Mag vs. the 496 HO. Every part was the same except the camshaft and ECU. Even the valve springs were the same. They basically undercammed the 496 to create the 496 Mag. The HO is pure profit for Mercury Marine, because it doesn't cost them a cent more to grind a cam differently or program an EUC for a 496 HO, but they charge about $4000 more than a non-HO. Marketing at its best! Gotta love em!
  4. #14
    Join Date
    Jan 2006
    Maybe the difference is only 27 HP. Check out the GM marine Hp/Torque charts here
Similar Threads
  1. 496 MAG or 454 MAG MPI
    By mg503 in forum Baja
    Last Post: 04-03-2013, 04:50 PM
  2. Replies: 23
    Last Post: 12-10-2007, 05:23 PM
  3. 496 mag into 496 ho parts
    By apexer in forum General Q & A
    Last Post: 07-20-2007, 07:24 PM
  4. 496 mag vs. 496 magHO
    By westcoaster in forum General Q & A
    Last Post: 08-08-2005, 11:24 AM
  5. difference between a 496 mag and 496 ho
    By NVRENOUGH in forum General Q & A
    Last Post: 02-18-2002, 12:25 PM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Powered by vBulletin® Version 4.2.0
Copyright © 2016 vBulletin Solutions, Inc. All rights reserved.
Search Engine Optimization by vBSEO 3.6.1
Original Poster In Postbit provided by Original Poster In Postbit v1.0.0 (Free) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd. Runs best on HiVelocity Hosting.
