35baja sst or35 fountain both wit th496 hos >
Old 06-08-2007, 12:12 AM
blume's Avatar
Default Gibbs
Dennis Gibbs in Dallas.....Gibbs Marine Surveyers?? 214-535-4588
blume is offline
Old 06-08-2007, 06:15 AM
Macklin's Avatar
I have ridden in a 35 Fountain on the lower Ches Bay washing machine water we typically run in. I was VERY impressed with the ride. I can't imagine the Baja ridding any better to be honest. And the Fountain will be much faster as mentioned. That boat should run right at 80 with dialed in props.
The Baja will have more room inside though. The cabin in the Fountain is a real back buster.
Both nice boats!
Macklin is offline
Old 06-08-2007, 06:22 AM
Driver-441
Racer
TeamSaris's Avatar
Received 1,073 Likes on 283 Posts
fountain been 92 ina 35 and shes rock solid.
TeamSaris is offline
Old 06-08-2007, 07:11 AM
You'd be surprised at the fit & finish of the new Baja 35 Outlaw. Very clean & logically laid-out, with plenty of room. Just be sure to get a survey done and see if the prior owners have books & records for any work that's been done.
It will be slower than the Fountain by a few mph because it's heavier, longer, and doesn't have a stepped hull. I also believe it would be more stable in rough water because of those things, too.
cbeastwood is offline
Old 06-08-2007, 07:30 AM
Tricky919's Avatar
Fountain.....
Tricky919 is offline
Old 06-08-2007, 07:41 AM
Reggie's Avatar
Wink
FOUNTAIN, you won't be sorry, if you get the Baja you'll wish you had the FOUNTAIN.
Reggie is offline
Old 06-08-2007, 07:50 AM
The new 35 OL is a pretty good boat and I understand that it is pretty fast too but you will enjoy the handeling and finish of the Fountain.
runafever is offline
Old 06-08-2007, 08:21 AM
Talking
It all depend's if you like that little Pointy, sticky outey thing on the front!
kennyo is offline
Old 06-08-2007, 08:25 AM
BajaRunner's Avatar
Id say go drive both and pick the one you like better. fountain is definately going to be faster, and probably a little nicer on fit and finish. The baja is going to ride a little better and probably be a little roomier (definately a bigger boat).
Then you get to price. The baja is probably cheaper. Its all preference.
BajaRunner is offline
Old 06-08-2007, 09:41 AM
QUOTE=kennyo;2155590]It all depend's if you like that little Pointy, sticky outey thing on the front![/QUOTE]
Thats funny! Both are great boats and the opinions stated above are for the most part correct.
JRalston is offline
Quick Reply: 35baja sst or35 fountain both wit th496 hos
