35baja sst or35 fountain both wit th496 hos
#41
fountain # 1,,,,,,baja is a bulky boat and dosent look near as sleek in the water or on the trailer........fountain is your best choice it may be a lil faster too.......and i think the fountain is more plush also .................FOUNTAIN all the way
#42
NO WAKE ENFORCER
Baja = mustang
Fountain = Vette
both production boats of similar quality and in a round about way owned or "guaranteed" by the same company
http://www.brunswick.com/brands/marine-boats/index.php
http://google.brand.edgar-online.com...F_Z&ID=4022704
my next boat will probably be a 25 or 26 outlaw best bang for the buck
#43
Received 3,017 Likes
I would take any Cig OR A BAJA over a Fountain EVERYDAY.
#44
#45
NO WAKE ENFORCER
#48
The stepped hull allows air to get in under the hull making it loose. This makes it a faster hull. It also effects the handling characteristics. Loose is fast but can be sloppy in turns if you dont know what you are doing. The Baja is a solid V hull. But the new 35 has been tested in wind tunnels to attempt to gain the same speed benefit from ventilating the hull. Without getting it loose in turns and rough water.
Most opinions here are good. Comes down to alot of personal preferences in style and look. If you want a boat that is a little bigger and has more interior room. Go with the Baja. If you want a little more speed and willing to sacrifice a little size and room. Go with the Fountain. I would be proud to own either one.
Best bit of advice. Go and look at both in person. Sea Trial both and make up your own mind about which one impresses and suits you the best.
