Help with alpha outdrive question
Whats the differences between the aphla 1 and the 2 ?
Will the II hold up better with a 454? Thanks Frank |
neither will hold up with a 454. There is a SS aplication that came with 454 for one year, but turned out to be not too reliable behind the power
Originally Posted by thedonz
(Post 2183772)
Thank you very much... Frank |
Alpha Generation 2
The Generation #2 Alpha has caused some confusion in the drive area. As of this date, Gen #2 drives are the latest smaller drive design. Both the transom assemblies and drives are NOT interchangable with the older units. The Gen #2 drives have a different mounting hole stud pattern. It LOOKS the same but it's different so an older Alpha or "R" drive will NOT bolt to a Gen#2 transom and vice versa. So... if you want a newer style Gen 2 Alpha then you will also need to replace the transom assembly to match it. One easy way to tell if you have a Gen#2 Alpha is to look at the way the upper is bolted to the lower. A Gen#2 uses through bolts to mate the upper to the lower. An older Alpha and "R" drives have nuts on studs. |
I have seen alpha's hold up to quite a bit of hp. It is all in how you run it! No holeshots and watch airing it out!
Originally Posted by DKerns
(Post 2184068)
John |
They're all the same.....
They had the Alpha (first one), Alpha R (Recent), Alpha MR (more recent), Alpha One, and Alpha GenII. I stopped working on this crap in 2000 so I'm sure they came out with something else after this... :rolleyes: :drink: The only major difference over the years from what I've seen are changes to the design of the cases but nothing really major. |
My set-up behind a BBC. I run it fast,not hard.
http://thumb15.webshots.net/t/62/462...5INLmmF_th.jpg |
That looks scary without external steering.I stripped out a steering arm on a Alpha and about killed my ex and me doing 65.I would think with all that setback there has got to be a ton of wear going on the tiller arm and shaft and gimbal ring.
