If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Follow us on Facebook Follow us on Twitter
Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: water problem
  1. #11
    Registered MitchStellin's Avatar
    My Boats:
    Zodiac RIB
    Join Date
    Nov 2000
    Grand Haven, MI USA
    How about a riser gasket, an 88 would need new ones for sure. If it is stock there should not be a problem, I had 88 454s and the riser gasket leaked and took out a cam lobe. Is the oil like milk?
  2. #12
    Join Date
    Jul 2007
    The riser has a valley on top that directs the water directly over the exhaust outlet so I'm adding a two inch extension to the end of that valley so the water will flow that much further past the outlet and hopefully it will not suck the water back in the exhaust.I will also check that my riser is 2" above my out let. Thanks to all for your help
Similar Threads
  1. please help 502 water problem
    By nwcrob in forum General Q & A
    Last Post: 01-05-2009, 01:44 PM
  2. Water Pressure Problem
    By nascar_crazy in forum Drives and Lower Units
    Last Post: 04-18-2008, 04:56 PM
  3. water problem
    By baja02 in forum General Q & A
    Last Post: 09-06-2007, 07:38 AM
  4. water leakage problem
    By edge_kw in forum General Q & A
    Last Post: 07-28-2006, 06:42 AM
  5. Another water pressure problem
    By candyman35 in forum General Q & A
    Last Post: 04-18-2002, 04:17 PM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Powered by vBulletin® Version 4.2.0
Copyright © 2016 vBulletin Solutions, Inc. All rights reserved.
Search Engine Optimization by vBSEO 3.6.1
Original Poster In Postbit provided by Original Poster In Postbit v1.0.0 (Free) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd. Runs best on HiVelocity Hosting.
