Big cubic inches or supercharger?
Mild Big Cube Motors that run on 87 octane and produce 600+ HP is the only way to go. They are strong and do not work hard to make power and the torque is unbeleivable!!! Dave
Depends on how much power your looking for,if you only want 650 or 700 hp build a N/A motor,my 8.22-1 540 made 657hp N/A at 5400 with fuel injection,you could run 87 octane and get 400 plus hours vs freshening a blower motor every 120-150 hours,Smitty
Supercharger.
Big cubes require tall decks, long cranks, short rods, and the pistons hang out the bottom of the cylinder. Big bores have thinner cylinder walls, and less room for future machining.
Large stroke crank throws are further away from the centerline of crank - increasing rotational mass. Not to menction the additional machine work large cubes can require.
There are more "off the shelf" parts for the 525 and smaller cubic inch engines.
Supercharger (lower CI) can have more friendly cams, and increase volumetric efficiency.
The "normally asparated clean horsepower" theory is bunk.
A centrifigual supercharger will "move" the horsepower higher in the curve which is "a little more outdrive friendly". The goal is to increase power so large CI v. supercharger and outdrive compatibality is a mute point.
A supercharger may be cheaper and more practical....but.....if you have the bucks.......supercharged and big cubes......and forgetaboutit.
call Crockette he has done both in 32 Sunsations, See what he thinks. I have had blowersin a 32 Sunsation that was tough to beat but I have a long idle in and out of my canal and the blowers seemed to load up. This might be fixed with fuel injection but I am no expert. I have a couple of approx 650 502 N/A now in my phantom and they seem to not have a issue with the long idle in and out. I sure like the sounds of a blower motor and maybe the next boat will be big cube blowers. Also Donminator Scott can give you all the in and out of what works on that boat. He has a Dominator running well over 100. He is the king of bling for Sunsation. Make sure you improve on the steering on your boat if you add much more power. It will be a must so add that in your projeetct's budg
