Depth sounder for step hulls
I'm looking to install a new sounder, because I've not been able to find the "sweet spot" for a good shoot thru location for the transducer. The one I purchased from West Marine seems to be a decent product, it's a "Hawkeye". I get depth readings when off plane, but as soon as I start to get on plane, depth goes away. I know it has to do with the steps, & I've got it mounted about 6" from the transom, & up from the keel. I've moved it 3 times, & the readings are the same. Perhaps I need to go to a different brand, or am I just going to have to bite the bullet & go to a transom mount. I am really trying to avoid that, but I may not have a choice. Anyone have the same trouble with the ZX, or any other stepped hull? I have considered mounting it in the forward bilge area, in front of the steps, but just not sure what, if any reading when on plane....Any tips will be greatly appreciated....
I have a step bottom and put a transducer that shoots thru the fiberglass. I put the transducer half way up from the transom and glued it to the fiberglass. No drilling or modification needed. It works great and is out of the way.
Originally Posted by VegasHallett
(Post 2242786)
What kind are you using I`ll be looking for one soon.
thanks |
You have to install the transducer in front of the first step.
The air bubbles created by the steps stop the unit from working. |
I looked this evening, it will be rather easy to move it up to the front bilge compartment. I'll move it & let ya know how it reads when on plane.
Also if your hull is cored ( bulsa or other ) the builder usually will have a spot with solid hull to mount the transducer.
You can't shoot through a cored hull. |
Originally Posted by Tinkerer
(Post 2243313)
You can't shoot through a cored hull. That's the correct answer! Dean |
In my opinion, all a depth finder does, is confirm the fact when you are hard aground. :eek:
Originally Posted by Dean Ferry
(Post 2243323)
BINGO,
That's the correct answer! Dean Brandon |
