What is Chime Walk
#41
No, it is when the cop makes you walk on your heals in a sobriety check lane This is an urban legend, just what is a "chine" I have never seen one, at least not in the wild.
#42
Here comes that freakin newbie again!
Someone explain to me why the following happens to me:
While running full throttle at 88-90mph with the drives trimmed out to ~4.5 and the tabs set on 3, the boat is stable and the water is consistent enough. I start to bring the tabs up to 2.5 and then 2. The boat will pretty much immediately start chine walking. Is this a result of the hull design or my lack of driving ability?
#43
My 17'-9" Switzer w/200hp Black Max would start to walk at about 65, then it settled down at 73 or so. I was told to drive through it and it worked...but the first time it was nerve-wracking to say the least. Prop & maybe 12" of keel in the water at 75-78; best conditions were 1' chop on the St. Lawrence river. The steering is key. Also, by myself the chine-walking was more severe due to uneven weight distribution, however getting a willing passenger to go along for the ride was not easy!
#44
With my boat and how it was set up, it would begin chine walking right around 80mph. WOT with this set-up would be right around 86-88mph---it wouldn't get squirrely, but rather it would violently bounce from side to side---it was pretty scarey. I believe the stern end had too much weight and the boat just wasn't balanced out correctly---something was badly amiss.
Maybe one of the reasons for this is because my drives were too deep in the water and the added weight of the extension boxes and how they (along with the drives) extended the weight of the boat out on the stern end with the leverage, but since I added those -2" shorties & 5-bladed props it is a totally different acting boat. The -2" shorties gave the drives a higher X dimension thus a different /more forward, flatter "angle of attack" and how it acts when I add trim. The stern/transom is lifted now and the balance and leverage is all different. The chine walk condition that I am speaking of has disappeared, but I can still get that "squirrely" feeling on top at WOT trimmed way out that I think you guys are speaking of.
Nice topic---I had been dealing with the "chine walk" (the kind of chine walk I am speaking of) for the last few years now.
Mark
#45
All you have to do to fix it is jerk the steering wheel to the left at just the right time to settle the boat down. Just make sure you jerk at the right time or it could get messy.
#47
LS
#48
If your "bounce" is to violent BE VERY CAREFUL WHEN PULLING BACK ON THOSE STICKS !!! OR BAAAAAD THINGS CAN AND HAVE HAPPENED>>>anytime i've operated a boat that started to DO A LIL DANCE "chine walk" its similar to a controled slide in a car, or street/dirt bike...a lil finesse a lil knowledge etc...i've been a passenger in a boat which was 36ft in length with twin 600's that would dance soooo bad at the 97-98mph mark would take a lot of fun outta the ride...but at 95-96 was stable as a rock
#50
Mobile,, I can agree with your last post ,,, if you have enough power and go faster ,, then your V bottem will lift to a point that it can walk ,, however if the bottem is right with the correct strakes place properly ,, the boat will not rock,, now if your lifting above the strake then in my opinion the boat could walk,,, makes sense to me !! (above means below )
RHC
RHC
