525 Header Failure??
Anyone know anything or got any experience with the headers on 525's failing due to corrosion. I've got one that basically turned to swiss cheese in about a two to three square inch section in the top of one of the tubes. I've heard rumblings that there have been problems with corrosion at other points (flanges) resulting in sea water leaking back into the head/cylinders. The reason for my question is I'm simply wondering if my other three headers are time bombs. At better than 4K a piece I'm not in a hurry to replace, but I certainly don't want to drown one of the motors either.
Thanks in advance.
C.
Thanks in advance.
C.
Charter Member #415
Salt water,even on immaculately maintained boats like yours ,is not kind to 525 headers. I have a customer in south Fl that has replaced a couple,a customer in Ca that has replaced 2,actually one today,and these were well maintained boats. And unfortunately,most extended warranty programs exclude the exhaust system
The new ones they make have a new design. They now have what they call a cool collar. These are better CMI says.
If you have a problem with one odds are you are going to have a problem with the others. We put 4 new ones on a few months ago, better safe than sorry.
No Comment
Location: This post copyright, Packinair Inc. All rights reserved.
This is Dan's dad.
Welcome to the CMI club!!!!
I work in aerospace and am fixng CMI headers all the time.
Unlike CMI, we don't let tubes fail at 40,000 feet!
I think we all expected more when we finally had enough money to buy a boat with stainless steel headers!
Right gang!?
Thank goodness for TIG welding!!!!
Right gang!?
I have one of the early 525's and before I bought my boat, the port side was replaced and then last year I had the starboard side let go, but it was fixable. I scored a very slightly used set from Tyler Crockett (mainly freshwater use) this year but I still have my old set. I wouldn't mind picking up some cash for them, but I'm so nervous right now about not having another set. Is there a way to tell if I have the cool collar set?
