Run Dry Impellers
Haven't used them, but will probably give them a try in the Spring. I have read that water pressure may go down a little with them. Thats fine with me since I'm at 32-34psi at wot.
They don't push enough water....but they do work......your motor will run hotter from what we have seen in every application.
Even though the impellor can last 15 min w/o water, what shape will the housing be in?
Every toasted impellor I've removed, also required the housing to be replaced do to it being melted and scored beyound use. |
Hmmm... I usually run my boat IN WATER. :D
Originally Posted by Clay Washington
(Post 2270497)
Michael Landis MJL Performance Inc 704-905-0086 |
Awesome for Stock applications
