Scoop Mounting Question
I know that in cars, the "ram air" effect does not start until 100+ mph. Before that, its just cold air induction.
I would say as long as you have cool air flooding the engine compartment you will be fine. I'm not sure if there is much of a gain past 100 either. Someone else here should know, and you can calculate it pretty easy also if you wanted to see how much pressure difference you would get.
1 Post
I've built a new hatch with two scoops for my old boat. The scoops were locally made [ similar to Harwoods ] and I cut them down for low profile look. Cut the ends off too , so the air flows right through .I have stainless screens in the intake and the rear oulet to keep any critters out . The ambient temperature is at least 20 degrees cooler in the engine bay now.Here are some pictures .
1 Post
We have a ZZ 572 in my friend's boat we put together 2 years ago . The engine is covered with an engine box inside the enclosed cabin .
We've installed a similar scoop on top of the cabin and air directed thruogh a duct .The temperature is a constant 72 degrees inside the engine bay at WOT .
1 Post
A one of kind , not for production. . My friend built the entire boat in 3 yrs, including the mold . He destroyed the mold afterwards. The boat is 33' , foam cored hull and weighs at 6000 lbs rigged . We had her up to 65 mph on GPS .
He's in the process of painting the hull sides blue and some simple trim colour. The wood inside is actually mahogany , and the headers are dry Stellings . He did the inside finishing on 'Status Quo' when he worked for Sovereign [ now Richmond Yachts] http://www.richmondyachts.com/gallery.html
I've been on 'Sun Chaser' to check it out while it was being finished, and it's one nice yacht too .
Here's a test run of Craig's boat from 2 yrs ago http://media.putfile.com/Craig-pushes-the-stick
Sonny Spectre 30
04-14-2004 07:34 AM
