The switches are really great, in many years of boating, only pulled it once (as I went overboard) But DO NOT give them to passengers. If you happens to come out, and you coast away about 1/4 mile, you'll need to go back and rescue them. While you're fumbling around looking for the cap to restart, you may loose you're overboard passenger.
ps; it doesn't matter how much they cost, if you save someone life it will be the cheapest accessory you ever buy!
Here is a copy of hte text from CP Performance web site.
This is the ONLY switch to run IMHO It could allow you or a passenger to restart the boat without hte lanyard. I have the KS-22 in my boat for hte twin emgine use. single is 19 bucks twin is 22 bucks CHEAP insurance Part No. : 855-KS-2 Category Brand Name Electrical - Kill Switches T & H Marine Saf-T-Stop Cut Off Switch - Single I/O with Coiled Lanyard For all inboard/outboard, inboard, dual inboard/outboard and dual inboard installations. Meets requirments of existing law covering mandatory use of emergency stop switches. Extra strong cloth covered self-retracting lanyard. Black matte finish for attractive appearance. Mounts in a 1-1/2'' diameter hole. Overall dimensions of switch housing are 2-3/4'' x 2'' and requires 1-1/2'' behind panel. Dual engine switches provide two completely isolated circuits to prevent feedback from on engine to the other. |
All the switch does is break the run wire coming off the ignition switch, thats why it will crank but wont fire with the switch pulled.
Thanks for the information!!
I just bought one from here http://www.boatfix.com/ It was under $20 as I recall. It is sitting here on my table. Now if I could only get the boat back from the mechanic, I could install it.
mine will NOT crank with it off
